Warning message
UCM 9 translation *XXXX
Jun 4th, 2014
trying to solve this problem.
I am 11 digit dialing in my dial plan to unity. Having issue with doing a direct transfer to voice mail
translation pattern:
*XXXX
transformation mass
XXXX
prefix
*1678507
results
  • esults Summary
    • Calling Party Information
    • Dialed Digits = *0521
    • Match Result = BlockThisPattern
    • Route Block Cause = Unallocated Number
    • Called Party Number = *6785070521
    • Time Zone = Etc/GMT
    • Outside Dial Tone = NO
  • Call Flow
    • TranslationPattern :Pattern=
      • Partition =
      • Positional Match List = *0521
      • Calling Party Number = 16785070521
      • PreTransform Calling Party Number =
      • PreTransform Called Party Number =
      • Calling Party Transformations
      • ConnectedParty Transformations
      • Called Party Transformations
  • Alternate Matches
    • Partition :Name= Atlanta-Xlate-VM-PT
      • Pattern
        • Pattern = *XXXX
        • Pattern Type = Translation
        • TranslationPartition = [2617faab-05bf-ec04-3c58-242dad4ba1ee]
        • CallManager Device Type = AccessDevice
        • PatternPrecedenceLevel = PlDefault
        • PatternRouteClass = RouteClassDefault
        • RouteNextHopByCgpn = false
now if I change it *0521 everything works as design.  what am I missinig.
change it to *052X -  does not work
change it to *052[1] works of course
change it to *052[01] does not work
looks like it not getting pass the translation.
I have a cti route point with forward all to vm (this part test ok)
*1XXXXXXXXXX
mmoulson1 Thu, 06/05/2014 - 04:16
  • Bronze, 100 points or more
Not sure exactly what you are trying to translate here!
Do you want *0521 to become *16785070521?
If so edit the 'Translation Pattern' to '*.XXXX'
Then on your 'Called Party Transformation' Set the 'Discard Digits' to 'PreDot', then set 'Prefix Digits' to '*1678507'
dshumake Thu, 06/05/2014 - 04:28
yes, I try that way with same results.
  • Results Summary
  • Call Flow
      • Partition =
        • Called Party Mask =
        • Discard Digits Instruction =
        • Prefix =
        • Called Number =
  • Alternate Matches
      • Pattern
        • Pattern = *.XXXX
        • TranslationPartition = [972728d3-9acc-fe0c-90a9-bab87a2daedd]
mmoulson1 Thu, 06/05/2014 - 04:40
In your above DNA your called party number is *6785070521 ?
Did you not want it to be: *16785070521 ?
If you look at the Route Block Cause = Unallocated Number, it means it's trying to dial something that does not exist.
dshumake Thu, 06/05/2014 - 04:44
with the "*", its going to vm.  even if the ext is wrong unity should still answer.
mmoulson1 Thu, 06/05/2014 - 04:55
So is this resolved or not?
dshumake Thu, 06/05/2014 - 04:57
no its not resolved, I have a lot users with ext starting with "0".   may need to open an tac case now
mmoulson1 Thu, 06/05/2014 - 05:01
I asked before did you want *0521 to become *16785070521?
In the DNA you posted  *6785070521 was displayed with a result of 'Unallocated Number'
So if it was *16785070521 would it match something and work?
When you say with the "*" it is going to VM? What do you mean?
dshumake Thu, 06/05/2014 - 05:04
Yes, I want it to become *16785070521
I am using the same translation and I am not sure why its removing the "1".
mmoulson1 Thu, 06/05/2014 - 05:11
Just looking at the DNA again and the *.XXXX being matched in Alternate Matches Partition :Name= Atlanta-Xlate-VM-PT.
Whereas your Call Flow:
Pattern=
Partition =
Are you matching some other blank translation in the <None> partition?
dshumake Thu, 06/05/2014 - 05:19
I notice that also, since i could not find where it is matching another PT, I created a new one (atlanta-xlate-vm-pt), put the translation in it and still had the same issue.  I have no null PT on the system.  the orignal was atlanta-xlate-pt
anyway I think I am hitting a bug or something.
thanks
mmoulson1 Thu, 06/05/2014 - 06:02
The only thing I can think to suggest is to check Call Routing, Route Plan Report. See if you can see anything rogue!
I assume you as you have added a new partition you have added to the appropriate CSS’s?
dshumake Thu, 06/05/2014 - 06:22
yes i did all of that...
here is the head scratcher....
I have another xlate which allow for 4 digit dialing to users line (long story on why it was design this way).  all lines has a 11 digit extension.  this works with no issues.
05[1-9]X (atlanta-xlate-pt)
prefix 1678507
int the CSS
ip-phone-pt
atlanta-xlate-vm-pt
atlanta-xlate-pt
vm-pt
this is the order  in the css
dshumake Thu, 06/05/2014 - 04:41
ok  here is what I found so far.
if the ext start with a "0" the wild card will not work (etc  XXXX), I have to put in the exact number in the translation.
other then that everything else works...  Now I need to find out whats causing this.
thanks
