Limit Peer to Peer communication for Wireless Guest users
Answered Question
Jun 5th, 2014
We have a WLAN configured on our WLC 5508 (7.5.102.0) for guest wireless users using simple PSK for authentication.  How can I block wireless guest devices from being able to see other devices on the same wireless network.   As an example if I run a ping sweep while connected to this network I get responses from other devices.  Basically I want to ensure that no devices are able to communicate on any level to other devices on that network but being able to access the default gateway for Internet access.
What's the best way to accomplish this?
Joe
Correct Answer by Leo Laohoo about 3 years 2 months ago
Under your SSID profile, go to Advanced > P2P Blocking Action.  Choose DROP.
Overall Rating: 5 (1 ratings)
Correct Answer
Leo Laohoo Thu, 06/05/2014 - 15:08
  • Hall of Fame,
    The Hall of Fame designation is a lifetime achievement award based on significant overall achievements in the community.
  • Cisco Designated VIP,
    2017 LAN, Wireless
Amjad Abdullah Sun, 06/08/2014 - 08:08
  • Red, 2250 points or more
Besides what Leo mentioned, you can do it from CLI:
config wlan peer-blocking drop <wlan ID>
To know your WLAN ID, use the command "show wlan summary".
Amjad
Trending Topics - Security & Network
