Warning message
ipsec vpn - not splitting traffic
Jun 5th, 2014
I have an ipsec vpn and it is up and running. On the remote asa I have the on the acl for the crytomap the inside network and destination the remote private network. I have also created a service policy rule where web traffic will not go to this tunnel but straight to the internet. I still find though that all traffic is going through the tunnel. How can I start resolving this? Thanks.
Overall Rating: 1 (1 ratings)
Marvin Rhoads Thu, 06/05/2014 - 14:38
  • Hall of Fame,
  • Cisco Designated VIP,
    2017 Firewalling, Network Management, VPN
Most likely your ACL used by the cryptomap is incorrect. If the traffic is deemed "interesting" by the ACL, it will be encapsulated in IPsec and the service-policy will never see it. (Step 4 vs Step 6 of packet processing - reference)
Can you share the configuration of the problematic ASA?
Or at least run a packet-tracer and let's look at the output of how the ASA handles the flow and why:
packet-tracer input inside tcp <inside client address> 1025 8.8.8.8 80 detailed
tolinrome tolinrome Thu, 06/05/2014 - 15:01
Here's a config of the remote 5505, thanks.
: Saved
ASA Version 9.1(4)
hostname
names
interface Ethernet0/0
 switchport access vlan 2
interface Ethernet0/1
interface Ethernet0/2
interface Ethernet0/3
interface Ethernet0/4
interface Ethernet0/5
interface Ethernet0/6
 description Access Point
interface Ethernet0/7
interface Vlan1
 nameif inside
 security-level 100
 ip address 10.25.40.200 255.255.255.0
interface Vlan2
 nameif outside
 security-level 0
 ip address 50.50.50.35 255.255.255.0
boot system disk0:/asa914-k8.bin
ftp mode passive
dns server-group DefaultDNS
same-security-traffic permit inter-interface
same-security-traffic permit intra-interface
object network NETWORK_OBJ_10.25.40.0_24
 subnet 10.25.40.0 255.255.255.0
object network 10.0.0.0
 subnet 10.0.0.0 255.0.0.0
object network 10.1.0.0
 subnet 10.1.0.0 255.255.0.0
object-group service DM_INLINE_TCP_1 tcp
 port-object eq www
 port-object eq https
access-list inside_nat0_outbound extended permit ip 10.25.40.0 255.255.255.0 any
access-list http-traffic extended permit tcp any any eq www inactive
access-list outside_cryptomap extended permit ip 10.25.40.0 255.255.255.0 object 10.1.0.0
access-list outside_cryptomap extended permit ip host 50.50.50.35 host 10.1.0.120
access-list outside_cryptomap extended permit ip host 10.25.40.200 host 10.1.0.120
access-list https-traffic extended permit tcp any any eq https inactive
access-list inside_access_in_1 extended permit tcp 10.25.40.0 255.255.255.0 any object-group DM_INLINE_TCP_1
access-list inside_access_in_1 extended permit ip any any
access-list global_mpc_1 extended deny tcp any object 10.1.0.0 eq https
access-list global_mpc_1 extended permit tcp any any eq https
access-list global_mpc extended deny tcp any object 10.1.0.0 eq www
access-list global_mpc extended permit tcp any any eq www
scansafe general-options
 server primary fqdn 69.174.87.51 port 8080
 server backup fqdn 70.39.231.99 port 8080
 retry-count 5
 license encrypted
pager lines 24
logging enable
logging asdm informational
mtu inside 1500
mtu outside 1500
icmp unreachable rate-limit 1 burst-size 1
asdm image disk0:/asdm-721.bin
no asdm history enable
arp timeout 14400
no arp permit-nonconnected
access-group inside_access_in_1 in interface inside
route outside 0.0.0.0 0.0.0.0 206.192.38.3 1
timeout xlate 3:00:00
timeout pat-xlate 0:00:30
timeout conn 1:00:00 half-closed 0:10:00 udp 0:02:00 icmp 0:00:02
timeout sunrpc 0:10:00 h323 0:05:00 h225 1:00:00 mgcp 0:05:00 mgcp-pat 0:05:00
timeout sip 0:30:00 sip_media 0:02:00 sip-invite 0:03:00 sip-disconnect 0:02:00
timeout sip-provisional-media 0:02:00 uauth 0:05:00 absolute
timeout tcp-proxy-reassembly 0:01:00
timeout floating-conn 0:00:00
dynamic-access-policy-record DfltAccessPolicy
user-identity default-domain LOCAL
aaa authentication ssh console LOCAL
http server enable
http 10.1.0.0 255.255.255.0 inside
http 10.1.11.0 255.255.255.0 inside
http 10.25.40.0 255.255.255.0 inside
crypto ipsec ikev1 transform-set ESP-AES-128-SHA esp-aes esp-sha-hmac
crypto ipsec ikev1 transform-set ESP-AES-128-MD5 esp-aes esp-md5-hmac
crypto ipsec ikev1 transform-set ESP-AES-192-SHA esp-aes-192 esp-sha-hmac
crypto ipsec ikev1 transform-set ESP-AES-192-MD5 esp-aes-192 esp-md5-hmac
crypto ipsec ikev1 transform-set ESP-AES-256-SHA esp-aes-256 esp-sha-hmac
crypto ipsec ikev1 transform-set ESP-AES-256-MD5 esp-aes-256 esp-md5-hmac
crypto ipsec ikev1 transform-set ESP-AES-128-SHA-TRANS esp-aes esp-sha-hmac
crypto ipsec ikev1 transform-set ESP-AES-128-SHA-TRANS mode transport
crypto ipsec ikev1 transform-set ESP-AES-128-MD5-TRANS esp-aes esp-md5-hmac
crypto ipsec ikev1 transform-set ESP-AES-128-MD5-TRANS mode transport
crypto ipsec ikev1 transform-set ESP-AES-192-SHA-TRANS esp-aes-192 esp-sha-hmac
crypto ipsec ikev1 transform-set ESP-AES-192-SHA-TRANS mode transport
crypto ipsec ikev1 transform-set ESP-AES-192-MD5-TRANS esp-aes-192 esp-md5-hmac
crypto ipsec ikev1 transform-set ESP-AES-192-MD5-TRANS mode transport
crypto ipsec ikev1 transform-set ESP-AES-256-SHA-TRANS esp-aes-256 esp-sha-hmac
crypto ipsec ikev1 transform-set ESP-AES-256-SHA-TRANS mode transport
crypto ipsec ikev1 transform-set ESP-AES-256-MD5-TRANS esp-aes-256 esp-md5-hmac
crypto ipsec ikev1 transform-set ESP-AES-256-MD5-TRANS mode transport
crypto ipsec ikev1 transform-set ESP-3DES-SHA esp-3des esp-sha-hmac
crypto ipsec ikev1 transform-set ESP-3DES-MD5 esp-3des esp-md5-hmac
crypto ipsec ikev1 transform-set ESP-3DES-SHA-TRANS esp-3des esp-sha-hmac
crypto ipsec ikev1 transform-set ESP-3DES-SHA-TRANS mode transport
crypto ipsec ikev1 transform-set ESP-3DES-MD5-TRANS esp-3des esp-md5-hmac
crypto ipsec ikev1 transform-set ESP-3DES-MD5-TRANS mode transport
crypto ipsec ikev1 transform-set ESP-DES-SHA esp-des esp-sha-hmac
crypto ipsec ikev1 transform-set ESP-DES-MD5 esp-des esp-md5-hmac
crypto ipsec ikev1 transform-set ESP-DES-SHA-TRANS esp-des esp-sha-hmac
crypto ipsec ikev1 transform-set ESP-DES-SHA-TRANS mode transport
crypto ipsec ikev1 transform-set ESP-DES-MD5-TRANS esp-des esp-md5-hmac
crypto ipsec ikev1 transform-set ESP-DES-MD5-TRANS mode transport
crypto ipsec ikev2 ipsec-proposal AES256
 protocol esp encryption aes-256
 protocol esp integrity sha-1 md5
crypto ipsec ikev2 ipsec-proposal AES192
 protocol esp encryption aes-192
crypto ipsec ikev2 ipsec-proposal 3DES
 protocol esp encryption 3des
crypto ipsec ikev2 ipsec-proposal DES
 protocol esp encryption des
crypto ipsec security-association pmtu-aging infinite
crypto map outside_map 1 match address outside_cryptomap
crypto map outside_map 1 set peer 50.50.50.250
crypto map outside_map 1 set ikev1 transform-set ESP-AES-128-SHA ESP-AES-128-MD5 ESP-AES-192-SHA ESP-AES-192-MD5 ESP-AES-256-SHA ESP-AES-256-MD5 ESP-3DES-SHA ESP-3DES-MD5 ESP-DES-SHA ESP-DES-MD5
crypto map outside_map 1 set ikev2 ipsec-proposal AES256 AES192 AES 3DES DES
crypto map outside_map interface outside
crypto ca trustpool policy
crypto ikev2 policy 1
 encryption aes-256
 integrity sha
 group 5 2
 prf sha
 lifetime seconds 86400
crypto ikev2 policy 10
 encryption aes-192
 integrity sha
 group 5 2
 prf sha
crypto ikev2 policy 20
 encryption aes
 integrity sha
 group 5 2
 prf sha
crypto ikev2 policy 30
 encryption 3des
 integrity sha
 group 5 2
 prf sha
crypto ikev2 policy 40
 encryption des
 integrity sha
 group 5 2
 prf sha
crypto ikev1 enable outside
crypto ikev1 policy 10
 authentication pre-share
 encryption aes-256
 hash sha
 group 2
 lifetime 86400
crypto ikev1 policy 65535
 encryption 3des
 hash sha
 group 2
 lifetime 86400
telnet timeout 5
ssh 10.0.0.0 255.0.0.0 inside
ssh 0.0.0.0 0.0.0.0 outside
ssh timeout 5
ssh key-exchange group dh-group1-sha1
console timeout 0
management-access inside
vpnclient server 50.50.50.250
vpnclient mode network-extension-mode
vpnclient nem-st-autoconnect
vpnclient vpngroup L2L password
vpnclient username L2LVPN password
dhcpd auto_config outside
dhcprelay server 10.1.0.120 outside
dhcprelay enable inside
dhcprelay setroute inside
dhcprelay timeout 60
threat-detection basic-threat
threat-detection statistics
threat-detection statistics tcp-intercept rate-interval 30 burst-rate 400 average-rate 200
tftp-server inside 10.1.0.200 ASA5505_run.txt
group-policy DfltGrpPolicy attributes
 vpn-tunnel-protocol ikev1 ikev2 ssl-clientless
tunnel-group 50.50.50.250type ipsec-l2l
tunnel-group 50.50.50.250ipsec-attributes
 ikev1 pre-shared-key
 ikev2 remote-authentication pre-shared-key
 ikev2 local-authentication pre-shared-key
class-map cws-http-class
 match access-list global_mpc
class-map http-class
 match access-list http-traffic
class-map cws-https-class
 match access-list global_mpc_1
class-map https-class
 match access-list https-traffic
class-map inspection_default
 match default-inspection-traffic
policy-map type inspect dns preset_dns_map
 parameters
  message-length maximum 512
policy-map type inspect scansafe https-pmap
 parameters
  default group httpstraffic
  https
policy-map type inspect scansafe cws_https-pmap
 parameters
  https
policy-map type inspect scansafe cws_http_pmap
 parameters
  default group httptraffic
  http
policy-map global_policy
 description cws-http-class
 class cws-https-class
  inspect scansafe cws_https-pmap fail-close
 class cws-http-class
  inspect scansafe cws_http_pmap fail-close
 class inspection_default
  inspect esmtp
  inspect ftp
  inspect h323 h225
  inspect h323 ras
  inspect icmp
  inspect ip-options
  inspect netbios
  inspect rsh
  inspect rtsp
  inspect skinny
  inspect sqlnet
  inspect sunrpc
  inspect tftp
  inspect xdmcp
policy-map type inspect scansafe http-pmap
 parameters
  http
service-policy global_policy global
prompt hostname context
no call-home reporting anonymous
call-home
 profile CiscoTAC-1
  no active
  destination address http https://tools.cisco.com/its/service/oddce/services/DDCEService
  destination address email [email protected]
  destination transport-method http
  subscribe-to-alert-group diagnostic
  subscribe-to-alert-group environment
  subscribe-to-alert-group inventory periodic monthly
  subscribe-to-alert-group configuration periodic monthly
  subscribe-to-alert-group telemetry periodic daily
: end
Marvin Rhoads Thu, 06/05/2014 - 22:26
  • Hall of Fame,
That looks more or less OK.
How about the packet-tracer output?
packet-tracer input inside tcp <inside client address from 10.25.40.0 subnet> 1025 8.8.8.8 80 detailed
tolinrome tolinrome Fri, 06/06/2014 - 05:17
packet tracer shows it going through the vpn. Maybe something on the other end of the asa?
Marius Gunnerud Fri, 06/06/2014 - 05:56
  • Red, 2250 points or more
    2017 Firewalling
How are you monitoring the traffic and identifying it is going over the VPN and not out to the internet?
Could you set up a packet capture on the inside interface and outside interface. In ASDM go to Wizards > Packet Capture.
If traffic is really going over the VPN when it is not supposed to you should not see any traffic in the packet capture on the outside interface.
Please remember to select a correct answer and rate helpful posts
tolinrome tolinrome Fri, 06/06/2014 - 19:12
Here's the output of the packet tracer:
ASA5505(config)# packet-tracer input inside tcp 10.25.40.101 1025 8.8.8.8$
Phase: 1
Type: ACCESS-LIST
Subtype:
Result: ALLOW
Config:
Implicit Rule
Additional Information:
 Forward Flow based lookup yields rule:
 in  id=0xd91cd538, priority=1, domain=permit, deny=false
        hits=1489754, user_data=0x0, cs_id=0x0, l3_type=0x8
        src mac=0000.0000.0000, mask=0000.0000.0000
        dst mac=0000.0000.0000, mask=0100.0000.0000
        input_ifc=inside, output_ifc=any
Phase: 2
Type: ROUTE-LOOKUP
Subtype: input
Result: ALLOW
Config:
in   0.0.0.0         0.0.0.0         outside
Phase: 3
Type: ACCESS-LIST
Subtype: log
Result: ALLOW
Config:
 port-object eq www
 in  id=0xd983dfe8, priority=13, domain=permit, deny=false
        hits=9517, user_data=0xd745b390, cs_id=0x0, use_real_addr, flags=0x0, protocol=6
        src ip/id=10.25.40.0, mask=255.255.255.0, port=0, tag=0
        dst ip/id=0.0.0.0, mask=0.0.0.0, port=80, tag=0, dscp=0x0
Phase: 4
Type: NAT
Subtype: per-session
Result: ALLOW
Config:
 in  id=0xd9228e20, priority=1, domain=nat-per-session, deny=true
        hits=161371, user_data=0x0, cs_id=0x0, reverse, use_real_addr, flags=0x0, protocol=6
        src ip/id=0.0.0.0, mask=0.0.0.0, port=0, tag=0
        dst ip/id=0.0.0.0, mask=0.0.0.0, port=0, tag=0, dscp=0x0
        input_ifc=any, output_ifc=any
Phase: 5
Type: IP-OPTIONS
Subtype:
Result: ALLOW
Config:
 in  id=0xd91d2fc8, priority=0, domain=inspect-ip-options, deny=true
        hits=91023, user_data=0x0, cs_id=0x0, reverse, flags=0x0, protocol=0
Phase: 6
Type: INSPECT
Subtype: np-inspect
Result: ALLOW
Config:
 in  id=0xd9766cd0, priority=70, domain=inspect-scansafe, deny=false
        hits=2134, user_data=0xd981e618, cs_id=0x0, use_real_addr, flags=0x0, protocol=6
Phase: 7
Type: HOST-LIMIT
Subtype:
Result: ALLOW
Config:
 in  id=0xd9201248, priority=0, domain=host-limit, deny=false
        hits=86435, user_data=0x0, cs_id=0x0, flags=0x0, protocol=0
Phase: 8
Type: VPN
Subtype: encrypt
Result: ALLOW
Config:
 out id=0xd97e9b90, priority=70, domain=encrypt, deny=false
        hits=448, user_data=0x31eadc, cs_id=0xd984d768, reverse, flags=0x0, protocol=0
        input_ifc=any, output_ifc=outside
Phase: 9
Type: VPN
Subtype: ipsec-tunnel-flow
Result: ALLOW
Config:
 Reverse Flow based lookup yields rule:
 in  id=0xd9805520, priority=70, domain=ipsec-tunnel-flow, deny=false
        hits=448, user_data=0x320edc, cs_id=0xd984d768, reverse, flags=0x0, protocol=0
        dst ip/id=10.25.40.0, mask=255.255.255.0, port=0, tag=0, dscp=0x0
        input_ifc=outside, output_ifc=any
Phase: 10
Type: NAT
Result: ALLOW
Config:
        hits=161373, user_data=0x0, cs_id=0x0, reverse, use_real_addr, flags=0x0, protocol=6
Phase: 11
Type: IP-OPTIONS
Subtype:
Result: ALLOW
Config:
 in  id=0xd91fcc70, priority=0, domain=inspect-ip-options, deny=true
        hits=177513, user_data=0x0, cs_id=0x0, reverse, flags=0x0, protocol=0
Phase: 12
Type: FLOW-CREATION
Subtype:
Result: ALLOW
Config:
New flow created with id 135803, packet dispatched to next module
Module information for forward flow ...
snp_fp_tracer_drop
snp_fp_inspect_ip_options
snp_fp_tcp_normalizer
snp_fp_inline_tcp_mod
snp_fp_translate
snp_fp_adjacency
snp_fp_encrypt
snp_fp_fragment
snp_ifc_stat
Module information for reverse flow ...
snp_fp_tracer_drop
snp_fp_ipsec_tunnel_flow
snp_fp_translate
snp_fp_adjacency
snp_fp_fragment
snp_ifc_stat
Result:
input-interface: inside
input-status: up
input-line-status: up
output-interface: outside
output-status: up
output-line-status: up
Action: allow
ASA5505(config)#
Marius Gunnerud Sat, 06/07/2014 - 13:04
    2017 Firewalling
Did you have a different ACL configured for the crypto map previously?
It is odd that it is not matching on the configured ACL.  If you look in the ASDM does the ACL match that which you see in the CLI?
Have you tried removing the command crypto map outside_map 1 match address outside_cryptomap and then re adding it again?
MANI .P Mon, 06/09/2014 - 03:39
@warrenroseny : One more option is available . install the wireshark  capture the packet meanwhile open the browser ... easy way to identify !!!
