Bogen PCM TIM MGCP Integration
Jun 5th, 2014
  • Bronze, 100 points or more
I am wondering if anyone has any recent experience with integrating a 2900 series ISR with a Bogen PCM TIM module?
 The Bogen documentation states you can use FXS or FXO however I have seen some cisco documentation on the subject stating that if you are utlizing MGCP on the gateway then you can not use an FXO port.  The document is from a long time ago!
