ipsec half working
Answered Question
Jun 6th, 2014
Hi Everyone,
Thanks for taking the time to read my post.
Using ISO version 12.4(13r)T11
i have setup a IPSEC tunnel between my cisco 2821 and a UBNT device.  The LAN on the 2821 side is 10.0.1.x and the lan on the UBNT side is 10.0.2.x.  The internet is in the middle.
from the ubnt device, they can access everything on the 10.0.1.x network but 10.0.1.x can not access anything on the 10.0.2.x network.  Im thinking i missed a no nat statement somewhere..  but where?
Current configuration : 4951 bytes
! Last configuration change at 00:15:28 EDT Sat Jun 7 2014 by a-rogarrett
! NVRAM config last updated at 23:12:54 EDT Fri Jun 6 2014 by a-rogarrett
version 12.4
hostname home1
boot-start-marker
boot-end-marker
enable secret 5 <removed>
aaa new-model
aaa authentication login default local
aaa authentication ppp default local
aaa session-id common
clock timezone EDT -4
ip cef
ip domain name <removed>
ip auth-proxy max-nodata-conns 3
ip admission max-nodata-conns 3
vpdn enable
vpdn-group 1
! Default PPTP VPDN group
 accept-dialin
  protocol pptp
  virtual-template 1
 l2tp tunnel receive-window 1024
voice-card 0
 no dspfarm
voice service voip
 clid substitute name
 allow-connections sip to sip
 no supplementary-service sip moved-temporarily
 no supplementary-service sip refer
 sip
  bind control source-interface GigabitEthernet0/1
  bind media source-interface GigabitEthernet0/1
  asserted-id ppi
  e911
  transport switch udp tcp
   outbound-proxy dns:<removed>
  no call service stop
username <removed> password 0 <removed>
crypto keyring orddie
  pre-shared-key address <UBNT IP ADDRESS> key <removed>
crypto isakmp policy 10
 encr aes 256
 authentication pre-share
 group 2
 lifetime 3600
crypto isakmp key <removed> hostname <UBNT dns name> no-xauth
crypto ipsec transform-set orddie esp-aes 256 esp-sha-hmac
crypto ipsec df-bit clear
crypto map orddie 10 ipsec-isakmp
 set peer UBNT Device IP
 set transform-set orddie
 match address 101
archive
 log config
  hidekeys
ip ssh authentication-retries 2
ip ssh version 1
interface GigabitEthernet0/0
 description Comcast
 ip address dhcp
 ip access-group 184 in
 ip nat outside
 ip virtual-reassembly
 duplex auto
 speed auto
 crypto map orddie
 description Network
 ip address 10.0.1.169 255.255.255.0
 ip nat inside
 duplex auto
 speed auto
interface Serial0/0/0
 no ip address
 shutdown
 clock rate 2000000
interface Serial0/0/1
 no ip address
 shutdown
 clock rate 2000000
interface Serial0/1/0
 no ip address
 shutdown
 clock rate 2000000
interface Serial0/1/1
 no ip address
 shutdown
 clock rate 2000000
interface Virtual-Template1
 ip unnumbered GigabitEthernet0/0
 ip nat inside
 peer default ip address pool ppp
 no keepalive
 ppp encrypt mppe auto
 ppp authentication pap chap ms-chap
ip local pool ppp 192.168.1.1 192.168.1.10
ip forward-protocol nd
ip route 0.0.0.0 0.0.0.0 dhcp
no ip http server
no ip http secure-server
ip nat inside source list 100 interface GigabitEthernet0/0 overload
access-list 100 remark Internal network
access-list 100 deny   ip 10.0.1.0 0.0.0.255 10.0.2.0 0.0.0.255
access-list 100 deny   ip 10.0.2.0 0.0.0.255 10.0.1.0 0.0.0.255
access-list 100 permit ip 10.0.1.0 0.0.0.255 any
access-list 100 permit ip 192.168.1.0 0.0.0.255 any
access-list 101 permit ip 10.0.1.0 0.0.0.255 10.0.2.0 0.0.0.255
access-list 101 permit ip 10.0.2.0 0.0.0.255 10.0.1.0 0.0.0.255
access-list 184 permit ip host UBNT Device IP any
access-list 184 permit ip host <removed> any
access-list 184 permit gre any any
access-list 184 permit tcp any any eq 1723
access-list 184 permit udp any any eq 1701
access-list 184 permit icmp any any echo
access-list 184 permit icmp any any echo-reply
access-list 184 permit udp any any eq bootpc
access-list 184 permit udp any any eq bootps
access-list 184 permit udp any any eq isakmp
access-list 184 permit udp host 75.75.75.75 eq domain any
access-list 184 permit udp host 75.75.76.76 eq domain any
access-list 184 permit udp host 8.8.8.8 eq domain any
access-list 184 permit udp any any eq ntp
access-list 184 permit udp any eq ntp any
access-list 184 permit tcp any eq www any
access-list 184 permit tcp any eq 443 any
access-list 184 permit udp any any eq non500-isakmp
control-plane
dial-peer voice <removed> voip
 destination-pattern <removed>
 session protocol sipv2
 session target ipv4:10.0.1.99
 session transport udp
 codec g711ulaw
dial-peer voice 10 voip
 destination-pattern 1..........
 session target dns:<removed>
sip-ua
<removed>
line con 0
line aux 0
line vty 0 4
 transport input ssh
line vty 5 15
 access-class 100 in
 transport input ssh
scheduler allocate 20000 1000
ntp clock-period 17180192
ntp server 17.151.16.21 prefer
end
Correct Answer by syed kazim abbas about 3 years 2 months ago
hi,
you have problem with ACL's:
you need to do this way: because Cisco recommend ACL should be mirror both sides.
no access-list 101 permit ip 10.0.2.0 0.0.0.255 10.0.1.0 0.0.0.255
and
no access-list 100 deny   ip 10.0.2.0 0.0.0.255 10.0.1.0 0.0.0.255
when u using pure IPSEC site to site not GRE over IPSEC then you need permit ESP not GRE
no access-list 184 permit gre any any
access-list 184 permit esp any any
the last one Cisco recommend for no-nat with route-map:
ip nat inside source route-map no-nat interface GigabitEthernet0/0 overload
route-map no-nat permit 10
match ip address 100
kazim
"please rate me, if post helpful"
Overall Rating: 5 (1 ratings)
Correct Answer
syed kazim abbas Sat, 06/07/2014 - 01:58
  • Bronze, 100 points or more
hi,
and
kazim
rbblue234 Sat, 06/07/2014 - 10:30
Thanks for the response!
I tried as you suggested, and now 10.0.2.x can no longer ping 10.0.1.x and 10.0.1.x can not ping 10.0.2.x.
Building configuration...
Current configuration : 4917 bytes
! Last configuration change at 13:17:44 EDT Sat Jun 7 2014 by a-rogarrett
! NVRAM config last updated at 13:17:47 EDT Sat Jun 7 2014 by a-rogarrett
version 12.4
hostname home1
boot-start-marker
boot-end-marker
aaa new-model
ip cef
ip domain name orddie.net
vpdn enable
vpdn-group 1
 accept-dialin
  protocol pptp
  virtual-template 1
voice-card 0
 no dspfarm
voice service voip
 sip
  asserted-id ppi
  e911
  pre-shared-key address <UBNT IP> key <removed>
 encr aes 256
 group 2
 lifetime 3600
crypto isakmp key <removed> hostname <UBNT HOSTNAME> no-xauth
 set peer <UBNT IP>
 match address 101
archive
 log config
  hidekeys
ip ssh version 1
 description Comcast
 ip address dhcp
 ip nat outside
 duplex auto
 speed auto
 crypto map orddie
 description Network
 ip nat inside
 duplex auto
 speed auto
 no ip address
 shutdown
 clock rate 2000000
 no ip address
 shutdown
 clock rate 2000000
 no ip address
 shutdown
 clock rate 2000000
 no ip address
 shutdown
 clock rate 2000000
 ip nat inside
 no keepalive
no ip http server
access-list 184 permit ip host <UBNT Host> any
control-plane
 codec g711ulaw
 session target <removed>
sip-ua
 <removed>
line con 0
line aux 0
line vty 0 4
 transport input ssh
line vty 5 15
 access-class 100 in
 transport input ssh
ntp clock-period 17180196
end
home1#
rbblue234 Sat, 06/07/2014 - 14:11
got it working.  was a firewall rule on the UBNT.
Thanks!
