Warning message
Problems with Cisco Stack C2960S-F48TS-L
Jun 8th, 2014
Hi all,
i tried to update one of my stack switches to a newer version.
Unfortunately, there seems to be an issue with the newer IOS version (or at least it is not synchronized) through all switches. I already tried to copy the bin files from the stack master through all stack members switch2 and switch3. The file were copied but there is no effort after reboot.
I'm getting "Version Mismatch". (different stack versions ?)
Is someone able to help me, what is the best way to add the two members back to the stack ?
Thanks in advance for any help!!!!
device#show switch
Switch/Stack Mac Address : 203a.07a3.0580
Mac persistency wait time: 4 mins
                                           H/W   Current
Switch#  Role   Mac Address     Priority Version  State
*1       Master 203a.07a3.0580     1      1       Ready
 2       Member 203a.07b1.f980     1      1       Version Mismatch
 3       Member 203a.07b1.f580     1      1       Version Mismatch
device#show switch stack-ports
  Switch #    Port 1       Port 2
    1           Ok           Ok
    2           Ok           Ok
    3           Ok           Ok
device#show version
Cisco IOS Software, C2960S Software (C2960S-UNIVERSALK9-M), Version 15.0(2)SE5, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2013 by Cisco Systems, Inc.
Compiled Fri 25-Oct-13 13:41 by prod_rel_team
ROM: Bootstrap program is C2960S board boot loader
BOOTLDR: C2960S Boot Loader (C2960S-HBOOT-M) Version 15.0(2r)SE, RELEASE SOFTWARE (fc1)
device uptime is 10 minutes
System restarted at 12:39:10 MET Sun Jun 8 2014
System image file is "flash:/c2960s-universalk9-mz.150-2.SE5"
cisco WS-C2960S-F48TS-L (PowerPC) processor (revision A0) with 131072K bytes of memory.
Processor board ID FOC1634W12G
Last reset from power-on
2 Virtual Ethernet interfaces
145 FastEthernet interfaces
12 Gigabit Ethernet interfaces
The password-recovery mechanism is enabled.
512K bytes of flash-simulated non-volatile configuration memory.
Base ethernet MAC Address       : 20:3A:07:A3:05:80
Motherboard assembly number     : 73-14896-02
Power supply part number        : 341-0529-01
Motherboard serial number       : FOC16340SHK
Power supply serial number      : DCB1629503Y
Model revision number           : A0
Motherboard revision number     : A0
Model number                    : WS-C2960S-F48TS-L
Daughterboard assembly number   : 73-14972-02
Daughterboard serial number     : FOC16332WKX
System serial number            : FOC1634W12G
Top Assembly Part Number        : 800-38492-01
Top Assembly Revision Number    : A0
Version ID                      : V01
CLEI Code Number                : CMMJP00ARA
Daughterboard revision number   : A0
Hardware Board Revision Number  : 0x00
Switch Ports Model              SW Version            SW Image
*    1 52    WS-C2960S-F48TS-L  15.0(2)SE5            C2960S-UNIVERSALK9-M
     2 0     WS-C2960S-F48TS-L  15.0(2)SE             C2960S-UNIVERSALK9-M
     3 0     WS-C2960S-F48TS-L  15.0(2)SE             C2960S-UNIVERSALK9-M
Switch 02
Switch Uptime                   : 10 minutes
Base ethernet MAC Address       : 20:3A:07:B1:F9:80
Motherboard serial number       : FOC16340SGU
Power supply serial number      : DCB1629503T
Daughterboard serial number     : FOC16332WH8
System serial number            : FOC1634W11M
Top assembly part number        : 800-38492-01
Top assembly revision number    : A0
Version ID                      : V01
Switch 03
Base ethernet MAC Address       : 20:3A:07:B1:F5:80
Motherboard serial number       : FOC16340SG3
Power supply serial number      : DCB162950D7
Daughterboard serial number     : FOC16332WR3
System serial number            : FOC1634W11L
Version ID                      : V01
Configuration register is 0xF
Leo Laohoo Sun, 06/08/2014 - 18:47
  • Hall of Fame,
    The Hall of Fame designation is a lifetime achievement award based on significant overall achievements in the community.
  • Cisco Designated VIP,
    2017 LAN, Wireless
Error message states that your stack master is running different version to the other two.  From the "sh version" it is evident that the stack master is running a buggy 15.0(2)SE5 while the two other stack members are running an equally buggy 15.0(2)SE.   This is the main reason why switches 2 and 3 won't join your stack.
My recommendation to you is to load 15.0(2)SE4 to all the switches INDEPENDENTLY.
If you have a spare USB stick, you can upgrade the two or three switches quickly if you load the IOS (TAR file) into a spare USB stick.  Make sure the USB stick is formated with FAT16 before you load the IOS into it.
Insert the USB to the switch you want to upgrade and console into it.  Issue the command "archive download-sw /over usbflash0:IOS.TAR" to start the switch upgrade process.
One the entire stack is upgraded to the same IOS version, then you can reload the entire stack.
Robert Mogan Thu, 06/12/2014 - 06:11
Hi Christian
I haven't had to do this for a while but as I remember it any problems were usually a file management or naming issue.
When copying the software image you want it to be in the same directory or path on each switch if possible. I'd usually just copy from flash on switch 1 to switches 2 and 3 (flash2: and flash3:)
#copy flash:c2960-blah-blah flash1:c2960-blah-blah
Just wondering if after you copied the images you remembered to update the boot path.
Troubleshooting steps:
1. Check you have copied the software image
# sho file systems
make a note of the flash directories eg flash1, flash2, flash3 then
#dir flash1:
#dir flash2:
#dir flash3:
Under the output to each of the above look to see that the new image is there - Do you have 2 images listed together - make a note of the new image name. If the new image is missing from any then you want to copy it again.
2. Does the boot path-list show the correct path/image under each switch or is it that switch 2 and 3 are still referencing the old path/image
#sho boot
If its correct then it should work.  If any are wrong you can update it with
config# boot system switch [number/all] [path/image]
Remember and do Wr Mem and reload and check again.
Hope it helps (:
Related Content
