Warning message
DCNM Discovery
Jun 10th, 2014
I'm having issues with DCNM discovering some Nexus 7K's.  Shallow discovery seems fine.  I enter the Nexus and its snmpv3 credentials in
DCNM> Admin>Data Sources>LAN
I enter the device as a single device in a switch list and it finds it as manageable.  I select the device and it goes into Discovering.
Sometimes it completes this part and allows me to go to Deep discovery.  Other times I get snmp timeout messages.  I have had it complete a deep discovery and show up on my topology map only for it to disappear a day later again with snmp timeout errors.  I've confirmed the snmpv3 credentials work with a 3rd party MIB browser which lets me test credentials and all is ok with them.
My first question is
The DCNM server seems to have an incorrect time.  Is this a possible issue ? If so how do I set the time ?  I've looked all over the GUI and can't find any place to set it.  Is it taken from the VM platform or is it set independently ?
Are there any other issues that may cause discovery problems ?
Thanks, Stuart.
eagles-nest Tue, 06/10/2014 - 04:26
Further troubleshooting has led me to put a capture on the Nexus to see if that sheds any light on what's going on.  I get the following output from the capture.
172.31.1.1 -> 172.30.1.1     SNMP Source port: 59596  Destination port: snmp[Malformed Packet]
That's from the DCNM server to the Nexus.
Stuart
Daniil Skopa Fri, 05/15/2015 - 06:53
I have the same issue.
Shallow discovery of Nexus 7k VDC randomly goes down with "Discovery timeout"  snmp error.
After rediscovery everything ok for a couple of minutes but then "Discovery timeout" appears again.
Waiting for relevant answer.
Thanks, Daniil.
