Warning message
Scansafe on Router - Commands missing
Jun 10th, 2014
  • Bronze, 100 points or more
Reading the document here - https://supportforums.cisco.com/document/147696/ios-scansafe-step-step-configuration
It states the following -
Prerequisite:
ISR should be running a minimum code version 15.2(1)T1 or above.
Available in IOS (universal) images with security feature set (SEC) license.
I am running the following - System image file is "usbflash0:c1900-universalk9_npe-mz.SPA.152-4.M4.bin"
But cannot see the following command - parameter-map type content-scan global
All I have available is
VPN(config)#parameter-map type ?
  waas  WAAS Parameter Map
Am I missing something?
Michael Douglas Wed, 06/18/2014 - 02:12
  • Cisco Employee,
to you have the Security k9 bundle on ISR-G2?
Did you also try the most recent image 15.3(3) M3?
Michael
