Cisco MCU MSE 8510 - guest PIN doesn't work
Answered Question
Jun 10th, 2014
We have few conferences setup on the 8510 blade. Each conference has the main PIN and the Guest PIN configured. When I dial into the conference, main PIN works fine but the guest PIN doesn't work.
I tried dialing in with the PIN from one endpoint, and then with the guest PIN from the other endpoint but the conference doesn't accept guest PIN. I can use the main PIN on both endpoints though.
Does anyone know what the issue may be?
Correct Answer by Patrick Sparkman about 3 years 2 months ago
I just tested this without 8510, no issues at all.
Can you give us a screenshot of how your conference is configured?
I had used the same Numeric ID for both chair and guest, with a different PIN for each.  When I connected as chair, I went straight in.  When I connected as guest, I went straight in, however I got a prompt saying saying on chairman to arrive or connect.
Overall Rating: 5 (1 ratings)
Correct Answer
Patrick Sparkman Wed, 06/11/2014 - 09:15
  • Purple, 4500 points or more
  • Cisco Designated VIP,
    2017 TelePresence
Krzysztof Mrocz... Fri, 06/13/2014 - 05:59
The issue is now resolved: Guest Numeric ID field was empty. Thanks for the advice!
Related Content
