Warning message
If a site has two WaaS appliances
Jun 10th, 2014
If a site has two WaaS appliances, can one work at peak performance while the secondary takes over when needed  (e.g. if the primary reaches its connection limit) or should the connections be equal between the two appliances?
SANTHOSHKUMAR S... Tue, 06/10/2014 - 20:14
  • Silver, 250 points or more
Hi ,
 How WAE devices is operated in your network inline method or Transparent method (WCCP or PBR) .
Sandy
