Tom Watts Thu, 06/12/2014 - 09:01
  • Green, 3000 points or more
Hi Acaz, this means the port is either hung or it is bad. You can try to clear the port by shutting it down and bringing it back up. You can also try to reboot or factory default the switch. If none of those clear it then the port is malfunctioning.
acazarkov Fri, 06/13/2014 - 00:28
on other port work link , the port is  broken :(
