Warning message
RPS2300 and internal Power on a 2960S
Jun 11th, 2014
If a switch is powered by an RPS, it is possible to identify if current is present in the internal power supply before switching back to internal power with the "power rps" command ?
With show env all I always see "Unavail", in both cases where current is present or not on the internal power supply.
The risk not knowing that, is when I issue the command "power rps 1 port 1 mode standby", I turn off the whole switch if no current is present on the internal power supply.
Any way to identify without going onsite and before issuing the command "power rps 1 port 1 mode standby" :
1) if voltage/current is present on internal power supply
2) if internal power supply is good or faulty
LHU-KOMSWE001#show env all
FAN is OK
SYSTEM TEMPERATURE is OK
System Temperature Value: 38 Degree Celsius
System Temperature State: GREEN
Yellow Threshold : 58 Degree Celsius
Red Threshold    : 68 Degree Celsius
SW  PID                 Serial#     Status           Sys Pwr  PoE Pwr  Watts
1  Built-in                                         Unavail
RPS Name: CiscoRPS
  State: Active
  PID: PWR-RPS2300
  Serial#: FDO1741YH3U
  Fan: Good
  Temperature: Green
DCOut  State   Connected  Priority  BackingUp  WillBackup  Portname        SW#
    1  Standby Yes               6  No         Yes          LHU-KOMSWE001     1
