port-channel question on 9148
ivy_yangxiaohua
hey I have a question about  port-channel.
we have a port-channel 10 which contains 4 interfaces as below.
my question is how the port-channel associated with the servers?  I mean the output "sh flogi database" as below........
do we need to add port-channel as a zone member ? I think the answer is no since I don;t see the port-channel as a zone member....
tormds01# sh interface port-channel  10
port-channel 10 is up
    Hardware is Fibre Channel
    Port WWN is 24:0a:54:7f:ee:a0:d5:48
    Admin port mode is auto, trunk mode is on
    snmp link state traps are enabled
    Port mode is F
    Port vsan is 510
    Speed is 32 Gbps
    5 minutes input rate 124316072 bits/sec, 15539509 bytes/sec, 9919 frames/sec
    5 minutes output rate 2205921104 bits/sec, 275740138 bytes/sec, 141424 frames/sec
      43540499847 frames input, 70772376296224 bytes
        0 discards, 0 errors
        0 CRC,  0 unknown class
        0 too long, 0 too short
      237450525827 frames output, 442040501099476 bytes
      0 input OLS, 0 LRR, 0 NOS, 0 loop inits
      0 output OLS, 0 LRR, 0 NOS, 0 loop inits
    Member[1] : fc1/1
    Member[2] : fc1/5
    Member[3] : fc1/9
    Member[4] : fc1/13
    Interface last changed at Tue Apr  8 22:16:49 2014
tormds01# sh flogi database
INTERFACE        VSAN    FCID           PORT NAME               NODE NAME
fc1/3            510   0x860000  50:06:01:64:3d:e0:24:d0 50:06:01:60:bd:e0:24:d0
                           [torvnx01_spa0]
fc1/7            510   0x860100  50:06:01:6c:3d:e0:24:d0 50:06:01:60:bd:e0:24:d0
                           [torvnx01_spb0]
fc1/11           510   0x860200  50:06:01:60:3d:e0:24:d0 50:06:01:60:bd:e0:24:d0
                           [torvnx01_spa2]
fc1/15           510   0x860300  50:06:01:68:3d:e0:24:d0 50:06:01:60:bd:e0:24:d0
                           [torvnx01_spb2]
port-channel 10  510   0x860400  24:0a:54:7f:ee:92:3e:80 21:fe:54:7f:ee:92:3e:81
port-channel 10  510   0x860401  20:01:04:25:b5:3a:00:8f 20:01:00:25:b5:30:00:8f
                           [mcvhes0101hba0]
port-channel 10  510   0x860402  20:01:04:25:b5:3a:00:9f 20:01:00:25:b5:30:00:9f
                           [mcvhes0102hba0]
port-channel 10  510   0x860404  20:01:04:25:b5:3a:00:6f 20:01:00:25:b5:30:00:6f
                           [mcvhes0103hba0]
port-channel 10  510   0x860408  20:01:04:25:b5:3a:00:7f 20:01:00:25:b5:30:00:7f
                           [mcvhes0104hba0]
port-channel 10  510   0x86040f  20:01:04:25:b5:3a:00:4f 20:01:00:25:b5:30:00:4f
                           [mcvhes0105hba0]
port-channel 10  510   0x860410  20:01:04:25:b5:3a:00:5f 20:01:00:25:b5:30:00:5f
                           [mcvhes0106hba0]
port-channel 10  510   0x860417  20:01:04:25:b5:3a:00:2f 20:01:00:25:b5:30:00:2f
                           [mcvhes0107hba0]
port-channel 10  510   0x860418  20:01:04:25:b5:3a:00:0f 20:01:00:25:b5:30:00:0f
                           [mcvhes0109hba0]
port-channel 10  510   0x86041b  20:01:04:25:b5:3a:00:bf 20:01:00:25:b5:30:01:bf
                           [mcvhes0110hba0]
port-channel 10  510   0x86041d  20:01:04:25:b5:3a:00:1f 20:01:00:25:b5:30:00:1f
                           [mcvhes0111hba0]
port-channel 10  510   0x86041e  20:01:04:25:b5:3a:00:3f 20:01:00:25:b5:30:00:3f
                           [mcvhes0108hba0]
port-channel 10  510   0x86041f  20:01:04:25:b5:3a:00:ff 20:01:00:25:b5:30:01:ff
                           [mcvhes0112hba0]
port-channel 10  510   0x860423  20:01:04:25:b5:3a:00:df 20:01:00:25:b5:30:01:df
                           [mcvhes0113hba0]
port-channel 10  510   0x860425  20:01:04:25:b5:3a:00:ef 20:01:00:25:b5:30:01:ef
                           [mcvhes0114hba0]
port-channel 10  510   0x860426  20:01:04:25:b5:3a:00:cf 20:01:00:25:b5:30:01:cf
                           [mcvhes0115hba0]
port-channel 10  510   0x860427  20:01:04:25:b5:3a:00:8e 20:01:00:25:b5:30:01:8f
                           [MCDBWS0200hba0]
port-channel 10  510   0x860429  20:01:04:25:b5:3a:00:9e 20:01:00:25:b5:30:01:9f
                           [MCDBWS0201hba0]
port-channel 10  510   0x86042a  20:01:04:25:b5:3a:00:7e 20:01:00:25:b5:30:01:7f
                           [mcvhes0118hba0]
port-channel 10  510   0x86042b  20:01:04:25:b5:3a:00:af 20:01:00:25:b5:30:01:af
                           [mcvhes0116hba0]
port-channel 10  510   0x86042c  20:01:04:25:b5:3a:00:6e 20:01:00:25:b5:30:01:6f
                           [mcvhes0117hba0]
port-channel 10  510   0x86042d  20:01:04:25:b5:3a:00:4e 20:01:00:25:b5:30:01:4f
                           [mcvhes0119hba0]
port-channel 10  510   0x86042e  20:01:04:25:b5:3a:00:5e 20:01:00:25:b5:30:01:5f
                           [mcvhes0120hba0]
port-channel 10  510   0x860431  20:01:04:25:b5:3a:00:2e 20:01:00:25:b5:30:01:2f
                           [awotorprodsql01hba0]
port-channel 10  510   0x860432  20:01:04:25:b5:3a:00:3e 20:01:00:25:b5:30:01:3f
                           [awotorprodsql02hba0]
port-channel 10  510   0x860435  20:01:04:25:b5:3a:00:fe 20:01:00:25:b5:30:00:ef
                           [dbcactv01n3hba0]
port-channel 10  510   0x860436  20:01:04:25:b5:3a:00:de 20:01:00:25:b5:30:00:bf
                           [dbcactv01n4hba0]
port-channel 10  510   0x860439  20:01:04:25:b5:3a:00:ce 20:01:00:25:b5:30:00:8e
                           [mcvhes0123hba0]
port-channel 10  510   0x86043a  20:01:04:25:b5:3a:00:be 20:01:00:25:b5:30:00:af
                           [mcvhes0122hba0]
port-channel 10  510   0x86043c  20:01:04:25:b5:3a:00:ae 20:01:00:25:b5:30:00:9e
                           [mcvhes0124hba0]
port-channel 10  510   0x860443  20:01:04:25:b5:3a:00:8d 20:01:00:25:b5:30:00:6e
                           [mcvhes0125hba0]
port-channel 10  510   0x860445  20:01:04:25:b5:3a:00:ee 20:01:00:25:b5:30:00:cf
                           [mcvhes0121hba0]
port-channel 10  510   0x860446  20:01:04:25:b5:3a:00:9d 20:01:00:25:b5:30:00:7e
                           [mcvhes0126hba0]
port-channel 10  510   0x860447  20:01:04:25:b5:3a:00:6d 20:01:00:25:b5:30:00:4e
                           [mcvhes0127hba0]
port-channel 10  510   0x860449  20:01:04:25:b5:3a:00:7d 20:01:00:25:b5:30:00:5e
                           [mcvhes0128hba0]
Walter Dey
I think what you do is F-Port trunking channeling !
port-channel as a zone member ? I assume you will do pwwn based zoning; in which case the answer is NO !
