Warning message
IP-IVR 8 with HTTPS
Jun 13th, 2014
Hi to everybody
I have a problem with https WebServices with self-signed certified.
In NetBean i have realized a java class, after i add certificate to keystore. I send a Soap Request message and receive a Soap Response message
It's work fine. Then I have upload my jar into IP-IVR, but i don't know how add self-signed certificate to keystore of JVM
Any idea ??? It's possibile to do??
Into cisco document I have read
Typically, the UCCX Engine's keystore would be invoked when script steps such as Get URL Document are
connected to a HTTPS target. The default Java keystore contained preinstalled root certificates from
well−known third party Certificate Authorities (CA). But, since the default Java keystore was protected by
Remote Support Account/root access, customers and partners were not able to upload certificates to the
keystore for SSL targets with self−signed certificates or other certificate chains that required
manually−populating the keystore with a certificate."
I have IP-IVR 8.0.2
thank you
Fabio
Samuel Womack Fri, 06/13/2014 - 07:25
  • Silver, 250 points or more
Open a Support Case with Cisco TAC..this is the only way to get the cert in the java trust store in a supported means..
