06-15-2014 10:59 PM
I have CIsco LMS 3.2
The problem is that one of the locations which was installed with CIsco 1841 Router has been replaced with Cisco 1941
from where i can get the report displaying the previous and the new replaced model ?
06-16-2014 02:21 AM
hi ,
As such there is no report to tell you about the Device change or replaced.
If you have not deleted the previous device 1841 and added the new one(1941) in LMS . you can still run reports for 1841 which will show you the old database information.
similarly you can run the report for 1941 as well.
Reports > Inventory > Detailed Device
Thanks-
Afroz
****Ratings Encourages Contributors ***
06-16-2014 04:47 AM
Thanks for the reply Afroz,
no i havnt deleted the previous device , the new was replaced at the end location
now when i run the report from inventory it gives me current device information ,not the previous device
06-16-2014 04:55 AM
Are you able to see the old device in LMS ?
06-16-2014 05:10 AM
i did nothing in the LMS, at the end location device was replaced and snmp credentials were entered , LMS updated itself with the new details under the previous device credentials.
Now i cant see what was the last device under the same name in LMS
06-16-2014 05:12 AM
database has been updated , so unfortunately you won't be able see the old device information now
Thanks-
Afroz
***Ratings Encourages contributors **
06-16-2014 09:55 PM
sad :(
thanks for the help
