Warning message
ASR - 1002 and Ip radius
Jun 16th, 2014
hi all,
my customer trying to remove the aaa and tacacs server from the device and fails.
router#conf t
Enter configuration commands, one per line. End with CNTL/Z.
router(config)#no ip radius source-interface Loopback0 vrf DATA
router(config)#no ip radius source-interface Loopback0 vrf Mgmt
router(config)#do sh run | se radius
ip radius source-interface Loopback0 vrf BB2DATA
ip radius source-interface Loopback0 vrf Mgmt-intf
router(config)#no ip radius source-interface loo
router(config)#no ip radius source-interface loop
router(config)#no ip radius source-interface ?
<cr>
we also tried removing the ip radius without the interface and still shows up with the above results.
rebooting is not an option as this is on a production environment.
currently he is on  Cisco IOS Software, IOS-XE Software (PPC_LINUX_IOSD-ADVIPSERVICESK9-M), Version 15.2(1)S, RELEASE SOFTWARE (fc1)and I could not find any bug/s on cisco tools.
with kind regards,
Lance
nkarthikeyan Mon, 06/16/2014 - 03:12
  • Gold, 750 points or more
Hi Lance,
Can you try like this as mentioned in the below command. This might solve your problem.
conf t# default ip radius source-interface Loopback0 vrf DATA
I made this attempt in a lab scenario it worked out.
R1(config)#do sh runn | in blue
ip vrf blue
ip radius source-interface Loopback0 vrf blue
R1(config)#def
R1(config)#defa
R1(config)#default ip radius source-interface loopback 0 vrf blue
ip vrf blue
R1(config)#ip vrf
Hope this helps
Karthik
Lance Wendel Mon, 06/16/2014 - 04:57
Hi Karthik,
unfortunately it didnt worked, I have escalated the issue to TAC. the only thing I haven't done was to reload the device. its been up for over 2years and reload is not an option :(
regards,
lance
