Warning message
ISE Wireless endpoint license?
Answered Question
Jun 16th, 2014
Hi all! Which means endpoint wireless license for Cisco ISE. Access point or client device? For example: I have 1 WLC, 35 access points and 500 clients. How many licenses I need to buy?
Correct Answer by nspasov about 3 years 2 months ago
ISE licensing is based on endpoints authenticating to the network. So in your case if all 500 devices will be connecting to the network at the same time then you will need to purchase 500 licenses. Keep in mind that those are concurrent, thus, when a client leaves the network a license is freed up.
Hope this helps!
Thank you for rating helpful posts!
Overall Rating: 5 (1 ratings)
Correct Answer
nspasov Mon, 06/16/2014 - 12:44
  • Cisco Employee,
  • Cisco Designated VIP,
    2017 AAA, Identity and NAC Security
Hope this helps!
