Warning message
ip directed broadcast to an interface secondary address
Answered Question
Jun 17th, 2014
I have a new network going in place that's going to coexist with an existing network as a secondary IP address on the interface.  We have an application that uses broadcast to communicate.  I configured "ip directed broadcast" but it hasn't been working.  Is this possible to do with a secondary address?  Interface configuration is below:
interface Vlan108
 description users
 ip address 192.168.0.13 255.255.255.0 secondary
 ip address 10.61.8.1 255.255.255.0
 ip helper-address 10.61.1.26
 ip directed-broadcast
end
Correct Answer by Richard Burts about 3 years 2 months ago
I do not see a problem in this config. If a packet with destination address of 192.168.0.255 gets to the interface then I would expect that it would be sent out into the vlan as a local broadcast. Note that this broadcast would also be seen by host in the 10.68.8 network. Are you sure that packets for 192.168.0.255 are getting to the interface?
Rick
Overall Rating: 5 (1 ratings)
Correct Answer
Richard Burts Tue, 06/17/2014 - 06:42
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 LAN, WAN
Rick
riccobene Mon, 06/23/2014 - 11:01
This is correctly working, I was unsure if this worked on an interface with secondary and it definitely does.  Thanks!
