Warning message
%HWIC_HOST-1-RX_CRC_ERROR: HWIC_HOST: Host termination logic experienced an HWIC CRC error for Interface
Answered Question
Jun 17th, 2014
we observe errors logs on the router as below ,please check and update if its trouble issue or abnormal behavior as we dont see any Services interuppted in the router currently.
Jun 17 06:18:57.208: %HWIC_HOST-1-RX_CRC_ERROR: HWIC_HOST: Host termination logic experienced an HWIC CRC error for Interface Descriptor Block 0x30A5F9A0
Jun 17 06:19:08.632: %HWIC_HOST-1-RX_CRC_ERROR: HWIC_HOST: Host termination logic experienced an HWIC CRC error for Interface Descriptor Block 0x30A5F9A0
Jun 17 06:19:09.452: %HWIC_HOST-1-RX_CRC_ERROR: HWIC_HOST: Host termination logic experienced an HWIC CRC error for Interface
LS-EMAX-LAMCY-MPLS uptime is 18 weeks, 21 hours, 38 minutes
System restarted at 08:52:33 UTC Mon Feb 10 2014
System image file is "usbflash0:c1900-universalk9-mz.SPA.151-4.M4.bin"
Last reload type: Normal Reload
LS-EMAX-LAMCY-MPLS#
NAME: "CISCO1921/K9 chassis", DESCR: "CISCO1921/K9 chassis"
PID: CISCO1921/K9 , VID: V05 , SN: FCZ1652902A
NAME: "Enhanced High Speed WAN Interface Card-1 Port Gigabit Ethernet SFP/Cu on Slot 0 SubSlot 0", DESCR: "Enhanced High Speed WAN Interface Card-1 Port Gigabit Ethernet SFP/Cu"
PID: EHWIC-1GE-SFP-CU , VID: V01, SN: FOC16486ADD
Correct Answer by Ankur Arora about 3 years 2 months ago
Its indeed the bug CSCuo71154
https://tools.cisco.com/bugsearch/bug/CSCuo71154/?reffering_site=dumpcr
There is no release where the bug is fixed at the moment, though there is a workaround by enabling flow control.
"Please rate the post if found useful"
Overall Rating: 5 (1 ratings)
acampbell Tue, 06/17/2014 - 14:46
  • Green, 3000 points or more
Looks like you are hitting bug CSCuo71154
This bug is as yet unresolved
Raise a TAC case and let Cisco know your IOS is affected
by the bug.
They may have a special release of IOS code for you to
use.
Hope this helps
Alex
Asim Afzal Fri, 06/20/2014 - 04:56
Thanks guys,
Let me do work around and will check
f-mullick Sun, 07/27/2014 - 17:30
Hi Asim, I have hit the same issue which I have reported out to TAC however can you please let me know what you workaround was which you mentioned?
samanepa Tue, 07/19/2016 - 13:31
Hello
Can someone update, if the IOS upgrade resolved this issue?
