Warning message
Problem to receive or make calls to or from different domains
Answered Question
Jun 17th, 2014
  I have a VCS Control and VCS Expressway, calls between registered devices including working properly.
  The problem when I want to call cisco example, do not know what settings should I add to be able to call someone who is not my domain or they can call me.
  There have been events cisco where you can enter via telepresence and I could not do me the following message:
Not registered - Destination not found
Correct Answer by Patrick Sparkman about 3 years 2 months ago
I suspect it's a configuration problem, where, I don't know.  We'll need some more information to be able to help find the issue.
  1. Are you able to contact others outside of your network, that isn't Cisco?
  2. Do you have a DNS zone configured on your VCS Expressway, and a search rule pointing to it?
  3. Are you able to see your call attempt in the Expressway search history?  If so, can you share it with us?
Overall Rating: 5 (1 ratings)
Correct Answer
Patrick Sparkman Tue, 06/17/2014 - 13:31
  • Purple, 4500 points or more
  • Cisco Designated VIP,
    2017 TelePresence
Vianyfel Cordaro Tue, 06/17/2014 - 13:48
I have not tried with other domains and not have anyone to try, I've only tested calls between registered with the VCS-E and VCS-C devices and  it works ... but I get calls because sometimes I have missed calls of numbers I know.
I attached you what you ask me.
Patrick Sparkman Wed, 06/18/2014 - 06:43
    2017 TelePresence
I just tried the Cisco address you had in your search history and was able to connect to there TelePresence Server.
Because the search history shows "Reason: Resolution failed" under your DNS zone, I'd suspect it's an issue with your DNS settings as it's not finding the called domains.  Can you confirm that the DNS settings are correct?
Vianyfel Cordaro Wed, 06/18/2014 - 09:02
Hi I change the IP address of the DNS because there had been a mistake but now following error appear in  the search rule
Patrick Sparkman Wed, 06/18/2014 - 09:18
    2017 TelePresence
Does the call go through?  I see that it found it, resulting in a good search, noted by "Found: True".
Which particular error in the search history are you wanting to know about?
Something else that might be a factor:
Where is your endpoint registered to, Control or Expressway?
What is interworking on the Expressway set to (Configuration > Protocols > Interworking)?
Vianyfel Cordaro Wed, 06/18/2014 - 09:31
OK, the endpoint its register on VCS-Expressway
Interworking was set to Only registered and change it to ON.
The output of the search now is :
Search details
You are here: Status Search history Search details
Displaying 1 search for this Search ID
Vianyfel Cordaro Wed, 06/18/2014 - 09:19
when I try to make the call using SIP, the search history displays the following:
Vianyfel Cordaro Wed, 06/18/2014 - 13:27
OK, I tried to the address you provided me and if it works now! Thank you for your help!smiley
