nat ip address communication issue between sites connected through VPN
Jun 18th, 2014
Need a little bit of guidance for the connectivity between 2 natted sites. I have 2 routers which will be doing natting (Internal -> nat IP) before going through the VPN tunnel.
Site A natting = 10.208.0.0 /16 to be natted to 1.1.0.0 /16
Site B natting = 10.208.0.0 /16 to be natted to 1.2.0.0 /16
I also added static route to point to the inside when the nat is coming from the outside but still no luck.
Configuration of Site A:
ip nat pool NATPOOL 1.1.0.0 1.1.255.255 netmask 255.255.0.0 type match-host
ip nat inside source route-map ROUTEMAP-NAT pool NATPOOL
route-map ROUTEMAP-NAT permit 10
match ip address ACL-NAT
ip access-list extended ACL-NAT
permit ip 10.208.0.0 0.0.255.255 1.2.0.0 0.0.255.255
! VPN encryption domain
ip access-list extended ACL-VPN
permit ip 1.1.0.0 0.0.255.255 1.2.0.0 0.0.255.255
ip route 0.0.0.0 0.0.0.0 GigbitEthernet0/0
ip route 1.1.0.0 255.255.0.0 GigabitEthernet0/1
interface GigabitEthernet0/0
crypto map S2S_IPSEC_VPN
ip nat outside
interface GigabitEthernet0/1
ip address 10.208.9.5 255.255.255.128
ip nat inside
Configuration of Site B:
ip nat pool NATPOOL 1.2.0.0 1.2.255.255 netmask 255.255.0.0 type match-host
permit ip 10.208.0.0 0.0.255.255 1.1.0.0 0.0.255.255
permit ip 1.2.0.0 0.0.255.255 1.1.0.0 0.0.255.255
interface Dialer1
ip nat outside
interface FastEthernet1
ip nat inside
ip address 10.208.76.102 255.255.255.0
ip route 0.0.0.0 0.0.0.0 Dialer1
ip route 1.2.0.0 255.255.0.0 FastEthernet1
With this configuration, I'm not able to ping from Site A (Lan IP) to the natted IP of Site B and vice versa.
Site A#ping 1.2.76.102 so gi0/1
Sending 5, 100-byte ICMP Echos to 1.2.76.102, timeout is 2 seconds:
Packet sent with a source address of 10.208.9.5
Success rate is 0 percent (0/5)
Site A#sh ip nat translations
Pro Inside global         Inside local          Outside local         Outside global
icmp 1.1.9.5:164          10.208.9.5:164        1.2.76.102:164        1.2.76.102:164
However, Site A I can see encaps on the ipsec incrementing but decaps shows the same, but on site B Im seeing incrementing decaps but not encaps. Same results I obtained when pinging site A from site B
Site B#ping 1.1.9.5 so fa1
Sending 5, 100-byte ICMP Echos to 1.1.9.5, timeout is 2 seconds:
Packet sent with a source address of 10.208.76.102
MY-PJ-DC-UNIFI-20M-S2S-RTR_1#sh ip nat tr
MY-PJ-DC-UNIFI-20M-S2S-RTR_1#sh ip nat translations
icmp 1.2.76.102:306    10.208.76.102:306  1.1.9.5:306        1.1.9.5:306
Whenever I do the ping test from site A, I dont see ip nat translation at all on Site B router. Same goes the other way around.
I've tried to use the reversible command on the ip nat source. With this command in place on router B, I am able to ping to the natted IP from Router A to Router B (With the condition that I tried to initiate ping traffics from Router B to Router A first. The ping test fails), but I still cant ping from router B to router A.
Router A results:
Router A#ping 1.2.76.102 so gi0/1
Success rate is 100 percent (5/5), round-trip min/avg/max = 8/8/8 ms
Router A#sh ip nat translations
icmp 1.1.9.5:174          10.208.9.5:174        1.2.76.102:174        1.2.76.102:174
Router B results:
Router B#sh run | i nat
ip nat inside source route-map ROUTEMAP-NAT-DKSH-CSSC pool NATPOOL-DKSH-MALAYSIA reversible
Router B#ping 1.1.9.5 so fa 1
MY-PJ-DC-UNIFI-20M-S2S-RTR_1#show ip nat translations
icmp 1.2.76.102:309    10.208.76.102:309  1.1.9.5:309        1.1.9.5:309
--- 1.2.76.102         10.208.76.102      ---                ---
jovie.siew Wed, 06/18/2014 - 01:57
Any suggestion or ideas would really be appreciated. I've spent a few days but I still cant come to a conclusion on what is wrong eventhough i made tons of research about natting process.
nkarthikeyan Wed, 06/18/2014 - 03:56
  • Gold, 750 points or more
Hi Jovie,
Can you try the NAT like the below and try? You can remove the present NAT rules and do this and give a try.
Site-A
ip nat inside source static network 10.208.0.0 1.1.0.0 /16 no-alias
Site-B
ip nat inside source static network 10.208.0.0 1.2.0.0 /16 no-alias
Also check if the inspection makes the issue @ one end.
Karthik
jovie.siew Wed, 06/18/2014 - 20:15
I've tried static nat, and yeah its working. I can ping both ways.
But my concern now is, on router A, we have exisiting VPN traffic to other branches. By doing static nat, I will be natting all traffics from 10.208.0.0 /16 on router A, which in turn affects all other VPN traffics to stop working.
Same goes to router B, we have other VPN setup currently.
I've made some research, but it seems that the command "ip nat inside source static network 10.208.0.0 1.1.0.0 /16 no-alias" is not able to support routemap to define what traffics will get natted. This particular command will nat all traffics from 10.208.0.0 /16 to 1.1.0.0/16.
I've tried a workaround, Router A we have several server IPs that remote sites will need to access. I can do a 1 to 1 static natting with route map to control the traffics.
On router B, I've tried using dynamic nat so we can control the traffic through route maps (with or without reversible command), but it seems like I can only ping 1 way.
Router A:
ip nat inside source static 10.208.9.5 1.1.9.5 route-map ROUTEMAP-NAT
Router B:
Results:
Router B#ping 1.1.9.5 so fa1
With reversible command, A can ping B but B unable to ping A
