Warning message
Catalyst 2960 uplink ports
Answered Question
Jun 20th, 2014
  • Silver, 250 points or more
is there any difference between uplink ports (using 1Gbps SFP) and any another 10/100/1000 port on Catalyst 2960X ?  What I mean is: if uplink port has a 1Gbps SFP and considering that standard port are 10/100/1000, is there a reason, for example related to Catalyst internal hardware and bus architecture, that should make me connect a server to the uplink port instead to any another port ?
Thank you a lot,
enrico.
Correct Answer by devils_advocate about 3 years 1 month ago
Although you can purchase Copper SFP's, people generally use the SFP ports on a switch to connect fibre cables to which means they they get the full 12/24/48 ports for their hosts.
Using one or more of the standard ports for uplinks means there are less for hosts but if you have spare and don't want the cost of running fibre and purchasing additional SFP's then use the normal ports.
Correct Answer by Leo Laohoo about 3 years 1 month ago
No difference whatsoever.  All the ports all share one single ASIC.
Overall Rating: 5 (2 ratings)
Correct Answer
Leo Laohoo Fri, 06/20/2014 - 03:36
  • Hall of Fame,
    The Hall of Fame designation is a lifetime achievement award based on significant overall achievements in the community.
  • Cisco Designated VIP,
    2017 LAN, Wireless
Correct Answer
devils_advocate Fri, 06/20/2014 - 03:54
  • Gold, 750 points or more
  • Community Spotlight Award,
    Small Business, November 2015
