Warning message
nkarthikeyan Mon, 06/23/2014 - 04:18
  • Gold, 750 points or more
I suggest you to go through the release notes of both the versions before you proceed.
for 8.6.1
http://www.cisco.com/c/en/us/td/docs/security/asa/asa84/release/notes/as...
for 9.1
http://www.cisco.com/c/en/us/td/docs/security/asa/asa91/release/notes/as...
Because any of the specific function you use might be an caveats here. So it worth reading the release notes before you.
But as far as i see both the OS are suggested by cisco as an preferred one.
Suggested ASA SW:
9.1.2
9.0.3
8.6.1
With respect to caveats 8.6.1 is considered as an stable one which has very few unresolved caveats.
Table 3 Open Caveats in ASA Version 8.6(1)
DDTS Number
Caveats
CSCtr71193
reload not performed when IPS software module in recover state
CSCts89380
Saleen: ASDM Handler does not support envmon psu power input sensor
CSCtt98015
Saleen: crypto engine archives continuous after license upgrade
CSCtu59747
Saleen: need to wait for 1 minutes before issue show inventory
CSCtv22976
Saleen crashed after negative test against tunnel limit
CSCtv27382
RDP and ICA plug-in issues with Saleen
Karthik
