Warning message
client exclusion of WLC
Answered Question
Overall Rating: 5 (1 ratings)
Saurav Lodh Wed, 07/09/2014 - 04:33
  • Gold, 750 points or more
Configuring Client Exclusion Policies (GUI)
    Step 1   Choose Security > Wireless Protection Policies > Client Exclusion Policies to open the Client Exclusion Policies page.
    Step 2   Select any of these check boxes if you want the controller to exclude clients for the condition specified. The default value for each exclusion policy is enabled.
    • Excessive 802.11 Association Failures—Clients are excluded on the sixth 802.11 association attempt, after five consecutive failures.
    • Excessive 802.11 Authentication Failures—Clients are excluded on the sixth 802.11 authentication attempt, after five consecutive failures.
    • Excessive 802.1X Authentication Failures—Clients are excluded on the fourth 802.1X authentication attempt, after three consecutive failures.
    • IP Theft or IP Reuse—Clients are excluded if the IP address is already assigned to another device.
    • Excessive Web Authentication Failures—Clients are excluded on the fourth web authentication attempt, after three consecutive failures.
    Issue the below command to see the time left when the client is excluded. default time is set to 60 sec.
    show exclusionlist
    Information similar to the following appears:
    Dynamically Disabled Clients
      MAC Address             Exclusion Reason        Time Remaining (in secs)
    00:40:96:b4:82:55         802.1X Failure          	51
    Correct Answer
    abwahid Tue, 07/22/2014 - 19:30
    • Bronze, 100 points or more
    Yes WLC will ignore the auth request as per exclusion policy you set.
    George Stefanick Wed, 07/23/2014 - 09:37
    • Purple, 4500 points or more
    • Community Spotlight Award,
      Best Publication, October 2015
    Actually, I think it ignores the probes, not the AUTHs. Going off memory ..
    Trending Topics - Security & Network
