Warning message
ME3600-X nile_dual_media_phy_set_one_feature() Failed to read MII_CONTROL for SFP PHY
Jun 23rd, 2014
  • Bronze, 100 points or more
Hi people,
we see this issue on one of our ME3600-X. I found this bug:
CSCub23041
Symptom:
My customers are seeing a "nile_dual_media_phy_set_one_feature() Failed to read MII_CONTROL for SFP PHY" error messages and ends up a old sfp's information is remained in "show inventry" log inspite of they has replaced it to other sfp in the same port.
Conditions:
unknown
Workaround:
reload
Fix is in 15.2(4)S1 but we had S2 running and error log was still there, and CPU usage is at over 80%.
Upgrade to 154-2.S did not help either.
We tried with one more reload but still the same. We could not find any logs that some SFP-s have been replaced before this issue.
smailmilak Tue, 01/06/2015 - 12:13
yes it was a SFP issue on port 1. Just remove it and everything should be ok.
acitycisco Mon, 03/23/2015 - 23:34
Just had same issue. Faulty SFP. Trashed it and problem gone.
