Flexible Netflow queries IOS-XE on 4500X
aacole
Level 5
Level 5
I'm in the process of configuring FNF on a C4500X switch running IOS-XE 03.05.03, the documentation is not too clear on some aspects of this.
I have it working when attached to a vlan, now I'm setting up another policy to attach to a port-channel configured as a layer 2 trunk.
First, what is the difference between the `match' and `collect' statement, they are not described in the configuration guide. I cannot find a command guide for this switch, does one exist?
I'm tried to apply this to the PO:
flow record REC02
! match interface input
 match datalink dot1q vlan input
! match datalink dot1q vlan output
! collect counter bytes long
! collect counter packets long
flow monitor NETFLOW-MON02
 exporter NETFLOW-EXPORTER
 cache entries 2000
 record REC02
int po10
ip flow monitor NETFLOW-MON02 layer2-switched input
The commented out lines are those that I've cut out one by one to get this to work, each time I get the error message:
% Flow Monitor: Flow Monitor 'NETFLOW-MON02' - Incompatible traffic type: Record has Datalink, monitor applied with IPv4
What am I doing wrong here??
TIA, Andy
orotter
Hi Andy ,
We also encountered this issue.
Did  you find a solution ?
Oded
roor
Hi Andy, Oded,
Apply the flow monitor you have defined as a datalink monitor instead of an ip monitor.
datalink flow monitor NETFLOW-MON02 layer2-switched input
HTH,
Roopa
