45003 E modules upgrade
Answered Question
Jun 25th, 2014
hi every one ,,
i have a switch 4503 E with the following modules installed on it :-
Mod Ports Card Type                                          Model
 1     2  Supervisor II+ 1000BaseX (GBIC)        WS-X4013+
 2    18  1000BaseX (GBIC)                              WS-X4418-GB
and i need to upgrade this modules to :-
( i'll change module number 2 and install 2 modules of the following :
2  X    WS-X4606-X2-E                     Catalyst 4500 E-Series 6-Port 10GbE
my question is : do i have to change any thing else in the switch to accomplish this task ( do i have to change the Supervisor II module ) ?
Correct Answer by adawa about 3 years 1 month ago
Hello, TamerAlDeeb2.
The WS-X4606-X2-E is supported on Supervisor Engine e 6-E, Supervisor Engine 6L-E, the Supervisor Engine 7-E, and the Supervisor Engine 7L-E. Supported chassis are Catalyst 4503-E, Catalyst 4506-E, Catalyst 4507R+E, Catalyst 4507R-E, and Catalyst 4510R+E switch chassis.
You can install it on any slot as long as it is not a supervisor engine slot, of course.
Please send me an e-mail ([email protected]), if you have additional concerns or need more support. Kind regards.
Overall Rating: 5 (1 ratings)
Correct Answer
adawa Wed, 06/25/2014 - 08:28
  • Bronze, 100 points or more
