Warning message
Unity Connection 9.1 - Voicemail button on phone
Answered Question
Jun 26th, 2014
We're running a newly upgraded version of Unity Connection 9.1 from Unity 7. After the upgrade, sometimes when we press the voicemail button on the phones it actually rings a few times before the voicemail attendant picks up and asks for your PIN. Does anyone know what could be causing this?
Correct Answer by David Hailey about 3 years 1 month ago
That's usually ok for a single server but for a cluster, generally should use Top Down ... sometimes it depends on how many ports you have as well (e.g. very large clusters).  If I were you, I'd try top down and see if it makes a difference for your application.  If not, probably will need to dig a bit deeper into topology and such.
Hailey
Overall Rating: 5 (1 ratings)
David Hailey Thu, 06/26/2014 - 08:36
  • Purple, 4500 points or more
In your hunt configuration in CUCM, what is the distribution algorithm you have set for the line group(s)?
Hailey
Correct Answer
David Hailey Thu, 06/26/2014 - 09:38
Hailey
cowetacoit Thu, 06/26/2014 - 09:51
that makes sense. i added a unity conn subscriber with an additional 16 ports. chenged CM to Top down and it seems good now. thanks!
David Hailey Thu, 06/26/2014 - 10:01
Good deal, glad to help.
Hailey
