Attendant Console Advance v 10.5
Jun 26th, 2014
Hi I have installed the Attendant Console Advance version 10.5 and all works fine except the blind transfer.
The procedure to make the blind transfer is the foloowing.
1) Receive Call
2) Type the extension and enter, but the call come back again.
The only way to make transfer is drag and drop or consult transfer.
Can somebody helpme?
Federico
Lisa Latour Wed, 04/01/2015 - 09:27
  • Silver, 250 points or more
hello - I have just moved your post to the Topic forums - you had posted your question in an obscure, non-visible, promotional community.  Hopefully our community users will see your question now.
tonyperla Thu, 04/02/2015 - 06:18
Hi Federico,
I know your post is a little dated but can you tell me what you have set under in the client -
Preferences then Advanced
In the "When Transferring Calls" section?
You may need to select "No Calls"
Hope this helps
Tony
Please rate helpful posts
antonio.vazquez Tue, 05/12/2015 - 09:38
  • Bronze, 100 points or more
Hi Federico,
have you solved this problem?
I have a similar problem, but only appears when I try to xfer the call outside the CUCM. My problem was that CTI Ports had not External Phone Number Mask.
Putting this, I have solved the problem but I have run into a new one. I have two calls in order to make the blind xfer (the first one is cancelled by CUCM).
