Warning message
asr9000 - flowspec
Jun 26th, 2014
We are waiting for 5.3.0 and FlowSpec indeed.
In the meantime Could you share any limitation and restriction with FLOWSPEC class based traffic drop ?
Did you do any interoperability tests with Juniper or/and ALU ?
KK
smilstea Mon, 06/30/2014 - 09:03
  • Cisco Employee,
BGP flowspec is coming in 5.2.0 which should be available later today for download along with the documentation.
Xander wrote a document on it here as well:
https://supportforums.cisco.com/document/12226726/asr9000xr-understandin...
I am not sure about interoperability testing, but hopefully this can help answer that question.
In 5.2.0 we use RFC 5575 as the base and have the following supported as well:
•IPv6 extensions: draft-ietf-idr-flow-spec-v6-03
•Redirect IP extension: draft-simpson-idr-flowspec-redirect-02
•IBGP extension: draft-ietf-idr-bgp-flowspec-oid-01
•Persistence Support:  draft-uttaro-idr-bgp-persistence-02
•HA/NSR Support.
On ASR9K we will initially support the Typhoon based LCs.
Sam
Konrad Kulikowski Wed, 07/02/2014 - 11:34
Thank you for information about supporting feature.
I am waiting but I don't see 5.2.0 on CCO.
Any update about release date ?
Konrad
smilstea Wed, 07/02/2014 - 12:30
  • Cisco Employee,
Hi Konrad,
It looks like the final build is almost ready, saw some final steps done today.
I'll update when I see it posted on CCO.
Sam
smilstea Fri, 07/04/2014 - 04:37
  • Cisco Employee,
Hi Konrad,
5.2.0 was just posted.
Cheers,
Sam
