Warning message
CUCX 8.5 Compatibility Matrix
Answered Question
Jun 27th, 2014
Hi All,
I have an existing environment :
CUCM : 8.6.2.20000-2
CXX : 8.5.1.10000-37
I want to upgrade my existing CUCM to version 10.5. Is CUCM 10.5 still can integrate with my existing CCX version ? or I also must upgrade my CCX to 10.5 ?
Because in compatibilty matrix document ,only CCX version 8 that can integrate with version 8 too. Below my reference document :
http://docwiki.cisco.com/wiki/Unified_CCX_Software_Compatibility_Matrix_...
Need your advice to solve my issue, Thank You.
Taufik
Correct Answer by Gergely Szabo about 3 years 1 month ago
No, they don't include later versions like 9.x or 10.x.
I have a bad experience of customers risking unsupported upgrades and then trying to force me to solve the situation. If it's unsupported, then it's unsupported, no exceptions.
G.
Overall Rating: 5 (1 ratings)
Gergely Szabo Fri, 06/27/2014 - 00:18
  • Green, 3000 points or more
  • Community Spotlight Award,
    Member's Choice, December 2015
you must adhere to the compatibility matrix. While integrating UCCX with an unsupported CUCM might work, there would be no guarrantees that such integrations would be free from errors. And of course, Cisco won't talk to you when you raise a support ticket if they find out this is an unsupported configuration.
G.
mtaufik_89 Fri, 06/27/2014 - 00:29
Hi Gergely,
Thanks for your reply.
I am sorry, I got the additional information on the link that said :
These Unified CM versions are supported - 8.0(1), 8.0(2) and all SUs, 8.5(1) and all SUs, Unified CM 8.6.2.22033, and later versions.
Is the word of "later versions" on that document meaning the CUCM 9 or 10 include ?
Or may be you have any experience regarding this integration that can be shared on this discussion.
Taufik
Correct Answer
Gergely Szabo Fri, 06/27/2014 - 00:39
G.
mtaufik_89 Sat, 06/28/2014 - 08:26
Hi Gergely,
Thank for your explanation. I will suggest my internal team to upgrade the CCX version to 10.5 (same with CCM). :)
Taufik
sysjes Wed, 08/06/2014 - 12:34
  • Bronze, 100 points or more
Some UCCX versions will support multiple CUCM major versions.  You will have to reference the latest CCX Compatability matrix.  If you're upgrading to CUCM 10.5, you may not have a choice, but upgrade to UCCX 10.5.
UCCX 8.5(1)SU4 supports up to 9.1(1)SU1.
8.5(1)SU2 and prior only supported up to CUCM 8.6(2a)SU3
http://docwiki.cisco.com/wiki/Unified_CCX_Software_Compatibility_Matrix_for_8.5(1)_SU4
http://docwiki.cisco.com/wiki/Unified_CCX_Software_Compatibility_Matrix_for_8.5(1)_SU2
UCCX 9.0(2)SU2 supports from 8.5(1) to 10.0(1) install a cop file to be compatible with 10.0.
http://docwiki.cisco.com/wiki/Unified_CCX_Software_Compatibility_Matrix_for_9.0(2)_SU2
Only UCCX 10.5(1) supports CUCM 10.5(1)
http://docwiki.cisco.com/wiki/Unified_CCX_Software_Compatibility_Matrix_for_10.5(1)
