06-27-2014 05:15 AM - edited 03-07-2019 07:51 PM
I'm trying to build a route-map that would take a route learned via BGP from an upstream peer, apply a local preference change to just this route, and leave all other routes unchanged. I've tried a few options in my lab, however it seems to change the route I'm matching via ACL and dropping all other routes I'm assuming due to the implicit deny. I figured then a prefix list would work but that doesn't seem to be the case either. Any ideas?
-Chris
Solved! Go to Solution.
06-27-2014 05:30 AM
Hello Chris,
this is a case for using an empty last block in the route-map
route-map CHANGEONE permit 10
match ...
set ...
route-map CHANGEONE permit 20
! emply final clause just to permit all the other routes
Hope to help
Giuseppe
06-27-2014 05:30 AM
Hello Chris,
match ...
set ...
Hope to help
Giuseppe
06-27-2014 01:35 PM
Thank you very much!
