UCCX 10.5 / Finesse - agent state error
Answered Question
Jun 27th, 2014
I am curently testing UCCX 10.5 and finesse agent desktop I have a trouble with finesse :
A agent is in READY state, when a call is comming, the state change to NOT READY, it should be TALKING
In the Agent state log is see NOT READY -> Reason code 32761, in the documentation I reed "Agent is logged in to the desktop or IP phone and receives a call that is not queued on the Unified CCX platform."
The caller is effectively an internal phone but the composed number is the CTI route point of the UCCX
I have check with "Reactive script" function of the CCX Editor, there is not any error, the call goes well through the script
Any idea ?
Hugo Chevalier
Correct Answer by Gergely Szabo about 3 years 1 month ago
just checking: the script sends the call to a CSQ and the agent is a member of that particular CSQ, is that correct?
G.
Overall Rating: 5 (1 ratings)
Correct Answer
Gergely Szabo Fri, 06/27/2014 - 09:01
  • Green, 3000 points or more
  • Community Spotlight Award,
    Member's Choice, December 2015
G.
Hugo Chevalier Sun, 06/29/2014 - 13:24
I test using the "select ressource" box, that way I am using a CSQ and it's works. Before, I was just testing with a "Redirect call" box and that is not the right solution.
Thank you
H.C
