uccx range of triggers with a single application
Jun 28th, 2014
I am using a range of triggers for one of my applications 1XXX. I am trying to get some reporting on the individual numbers dialed. I can get the number in the scripts by doing a Get Call Info - Dialed Number instead of Called Number.In 8.5 the Called Number Summary Activity Report shows the range in the report. It doesn't break down the numbers individually. I am seeing a report for "Dialed Number"
Neal haas Mon, 06/30/2014 - 08:58
Run an application report. It will show you all of the Trigger numbers dialed.
Kleid Gjataj Mon, 06/30/2014 - 09:43
thanks for the reply Neal but in the Application Report there is not way to group by called number
We are looking for a quick tally based on the number called
