06-29-2014 06:52 AM - edited 03-16-2019 11:14 PM
Hi to all
i have something strange here and i need your assistance
Call Flow:
Sip trunk-->UC540--> CUE
When calls coming to UC540 from outside and then going to cue then we send back service unavailable.I made a translation and i sent directly the incoming calls to CUE
The same behavior is also if i send the calls to dummy number and then from there set forward all to voice mail.
Incoming voicemail is working fine
Incoming calls to phones also ok
Uc540: 8.6
CUE: 8.6.5
A number: 99999999
B number: 22777777
Voice Mail Number:111
Attached is the trace
i see that we hit the correct dial peers .
I have enable only trancoder since MTP is not register ( don't know why , but i don't think also that is necessary..
voice service voip
ip address trusted list
ipv4 172.16.80.0 255.255.255.0
ipv4 172.16.81.0 255.255.255.0
allow-connections sip to sip
supplementary-service h450.12
no supplementary-service sip moved-temporarily
no supplementary-service sip refer
supplementary-service media-renegotiate
sip
no update-callerid
dial-peer voice 1000 voip
description **SIP TRUNK**
translation-profile incoming SIP-INCOMING
translation-profile outgoing SIP-OUTGOING
destination-pattern 9T
modem passthrough nse codec g711alaw
session protocol sipv2
session target sip-server
incoming called-number .T
voice-class codec 2
voice-class sip dtmf-relay force rtp-nte
dtmf-relay rtp-nte
fax-relay ecm disable
no fax-relay sg3-to-g3
fax rate 9600
fax protocol pass-through g711alaw
no vad
dial-peer voice 2001 voip
description ** cue voicemail pilot number **
destination-pattern 111
b2bua
session target ipv4:10.1.10.1
incoming called-number 111
no voice-class sip outbound-proxy
dtmf-relay sip-notify
codec g711ulaw
no vad
chrysostomos
06-29-2014 10:01 AM
Hi Chrysostomos,
Please set the allow connection under voip service to allow the call to move from one sip leg to other.
Voice service voip
allow connections sip to sip
Second as you are using b2bua on dial-peer then its important to configure media source ip , so that it modify the media ip/port and act as media flow-through mode.
on global mode...
voice service voip
sip
bind media source interface ......
bind media control interface .......
or configure it on dial-peer (recommended)
dial-peer voice xxxx voip
voice-class sip bind control source-interface ........
voice-class sip bind media source-interface .......
Collect the debug if it fails again.
Manish
07-30-2014 06:29 AM
Problem solved
It was a BUG to the IOS of UC540
Changed the ios fixed the problem
06-29-2014 12:47 PM
FastEthernet0/0 unassigned YES NVRAM up up
FastEthernet0/0.10 192.168.0.10 YES DHCP up up ----> For internet
FastEthernet0/0.20 10.151.5.130 YES NVRAM up up ------> For sip trunk
In0/0 10.1.10.2 YES unset up up --------> default gw for cue
Vlan1 unassigned YES unset up up
Vlan100 unassigned YES unset up up
Vlan200 unassigned YES unset up down
Vlan300 unassigned YES unset up down
NVI0 10.1.10.2 YES unset up up
BVI1 192.168.20.1 YES NVRAM up up
BVI100 10.1.1.1 YES NVRAM up up ---------> ip for cme
Loopback0 10.1.10.2 YES NVRAM up up ------> default gw for cue
b2bua
voice-class sip bind control source-interface BVI100
voice-class sip bind media source-interface BVI100
codec g711ulaw
no vad
interface FastEthernet0/0.10
description **FOR INTERNET**
encapsulation dot1Q 10
ip address dhcp
ip access-group 105 in
ip nat outside
ip inspect SDM_LOW out
ip virtual-reassembly in
interface FastEthernet0/0.20
description **FOR SIP TRUNK WITH ISP**
encapsulation dot1Q 20
ip address 10.151.5.130 255.255.255.240
ip route 10.1.10.1 255.255.255.255 Integrated-Service-Engine0/0
ping 10.1.10.1 source bvi100
Sending 5, 100-byte ICMP Echos to 10.1.10.1, timeout is 2 seconds:
Packet sent with a source address of 10.1.1.1
Success rate is 100 percent (5/5), round-trip min/avg/max = 1/1/1 ms
I have bind the interface of cme ( 10.1.1.1) but the call fails again
Anything to advice?
06-30-2014 02:23 AM
Which all codecs that voice-class codec 2 contains ?
The intial INVITE has little wired SDP parameters , it does not contains audio media attribute like this..
a=rtpmap:8 PCMA/8000
Nevertheless this attribute is not a mandatory parameters of SDP.
As only single media is offered from the initial INVITE i.e. G711alaw and you know CUE only supports ulaw , so you need transcoders to convert alaw to ulaw.
What is the trancoder status and how it is configured ?
Manish
06-30-2014 02:40 AM
Thank you for the response again
Yes i have a trancoder enable and is registered successfully
voice class codec 2
codec preference 1 g711alaw
codec preference 2 g711ulaw
codec preference 3 g729br8
codec preference 4 g729r8
sccp local bvi100
sccp ccm 10.1.1.1 identifier 1 version 7.0
sccp
sccp ccm group 1
associate ccm 1 priority 1
associate profile 1 register transcode
dspfarm profile 1 transcode
codec g729abr8
codec g729ar8
codec g711alaw
codec g711ulaw
codec g729r8
codec g729br8
maximum sessions 8
associate application SCCP
telephony-service
sdspfarm units 1
sdspfarm tag 1 transcode
show dspfarm all
Dspfarm Profile Configuration
Profile ID = 1, Service = TRANSCODING, Resource ID = 1
Profile Description :
Profile Service Mode : Non Secure
Profile Admin State : UP
Profile Operation State : ACTIVE
Application : SCCP Status : ASSOCIATED
Resource Provider : FLEX_DSPRM Status : UP
Number of Resource Configured : 8
Number of Resource Available : 8
Codec Configuration: num_of_codecs:6
Codec : g729br8, Maximum Packetization Period : 60
Codec : g729r8, Maximum Packetization Period : 60
Codec : g711ulaw, Maximum Packetization Period : 30
Codec : g711alaw, Maximum Packetization Period : 30
Codec : g729ar8, Maximum Packetization Period : 60
Codec : g729abr8, Maximum Packetization Period : 60
SLOT DSP VERSION STATUS CHNL USE TYPE RSC_ID BRIDGE_ID PKTS_TXED PKTS_RXED
0 1 28.3.10 UP N/A FREE xcode 1 - - -
0 2 28.3.10 UP N/A FREE xcode 1 - - -
0 3 28.3.10 UP N/A FREE xcode 1 - - -
06-30-2014 03:11 AM
Under telephony service you only have that much configuration ? I mean that you have to configure dummy DN and ephone under telephony service and also interface binding like this..
telephony service
max-dn 1
max-ephone 1
ip source-address 10.1.1.1 port 2000
ephone-dn 1
number xxxx
ephone 1
mac zzz.zzz.zzz
button 1:1
Then create cnf under telephony service..
And also add
sdpfarm transcode session 8 under telephony service.
Do a "no sccp" and then "sccp" and then test a call , if fails again send trace and "show sccp" logs.
Manish
06-30-2014 03:43 AM
My friend i have done thousands of UC implementations :) Yes its there all the appropriates configs.Just i upload here only the related with this issue
All the config is correct
Its seems that the trancoding is not working at all
May is a bug of the current software/IOS dont know
Current IOS:
boot system flash:/uc500-advipservicesk9-mz.151-4.M7
06-30-2014 03:52 AM
If trancoders are showing active in "show sccp" and configuration are correct , then it might be an IOS bug and you need to look at bug toolkit.
I will give a last try if you give me "debug ccsip all" only for a failing call to look at sip stack level trace.
Manish
06-30-2014 02:43 AM
