1142 status light not working
Jun 30th, 2014
I have 10 1142 LAP's that were working at various locations.  I have replaced them with other newer model AP's and wish to reuse them somewhere else.  I have connected them to WISM controllers to reconfigure but the green status light on each AP no longer burns.  The red, blue light works and the AP loads, but the green status light doesn't.  I issued a reset to the AP from the controller but no help.
Any ideas what has happened to the light and how to get it back on?
Leo Laohoo Mon, 06/30/2014 - 16:04
  • Hall of Fame,
    The Hall of Fame designation is a lifetime achievement award based on significant overall achievements in the community.
  • Cisco Designated VIP,
    2017 LAN, Wireless
Use the WLC CLI command:  config ap led-state enable all
Jimmy Long Tue, 07/01/2014 - 04:38
Leo... thanks for the reply but this command would not work on the AP.  When I telnet into the AP and go to enable mode I tried your command :  config ap led-state enable all
It gets an Invalid input error at the word config.  There also is no config command on the ? screens.  If I need to do something else please let me know.  There is an led command under enable but it just flashes the led.   thanks...
Leo Laohoo Tue, 07/01/2014 - 05:12
  • Hall of Fame,
    2017 LAN, Wireless
The command is NOT to be applied on the AP (as I've mentioned).
The command is to be applied on  the WiSM.
