Warning message
How to use subdomain at Jabber with IM and Presence 10.5
Jun 30th, 2014
  • Events Top Contributors,
    External, 2014
I successfully have installed CUCM, CUCM IM Presence 10.5 and populate my user with msRTCSIP-PrimaryUserAddress on the AD(sip:[email protected]).
And installed the expressway-C and expressway-E to do the MRA feature.
I am able to log on Jabber and have chat, calls, video, contact photos, contact informations and so on, but now I am trying to test the multiple IM domain feature (that is a requirements of my customer).
This is my environment:
[email protected]
[email protected]
[email protected]
User1 can search the User2 but the IM address shows as [email protected] (because of the domain of user1).
If the user1 manually insert the contact of user2 with IM address as [email protected], they can see, chat and call each other.
So, here are my questions:
1 - Is possible to Cisco Jabber client search directly the IM address as the Directory URI? If yes, how to do that ? (I tried <IMAddress use-default="false"> and <IMAddress prefix="sip:"> msRTCSIP-PrimaryUserAddress or <UseSIPURIToResolveContacts> but does not affect nothing).
2 - Is possible to use a wildcard mask at "Unified Communications IM domains" to all my domain when generating certificate on the Expressway-E? Since all the domains will be a "subdomain". Because if I have to add a new domain at presence, must put here to jabber works external.
Guilherme Henri... Tue, 07/01/2014 - 12:32
    External, 2014
At IM and Presence 10.5 it is possible to create many domains as you want. On the Presence Menu > Domains.
After that, I suggest you to change the Presence > Settings > Advanced configuration "IM Address Scheme" to Directory URI.
abdullah alnahdi Tue, 07/01/2014 - 14:02
Hi Henri
Thank in advanced for you help.This is my first time to install jabber can you help me if i have any issue
astrohmeier Wed, 01/07/2015 - 21:36
Hello Henri,
did you solve the Problem with the wrong IM address?
regards Achim
