MXE3500 IP streaming error
Jul 1st, 2014
Hi, I'm having trouble with live streaming from an MXE3500. When I submit a job the following error occurs:
Internal error, creating server control ( 800401f3 )
Microsoft worker warning: Alias ( Bruneltest ) not added to Microsoft Media Server ( 134.83.121.8 )
Not entirely sure what to do to sort this. To get to this point I've done the following:
1.Creating an IP Capture configuration for the source. In this case a WMV feed from a IP streaming box.
2. Created a Webcast Distribution Profile. Set to output to the correct IP/Port with assigned WMV encoding format with a lower lower res than the original
3. Created a Job profile using the correct Encoder and Webcast profiles.
4. Started a Live Job using the Job profile and IP capture. This then produces the error as soon as it reaches the Job Status queue.
To resolve this I've tried streaming in a number of different encoding formats, Tried a different initial stream and tried a complete terminal reset of the MXE3500. I can't see any reference to this error in any forum or in the MXE documentation so I'm a bit at a loss.
Any help on this would be appreciated
islam.kamal Wed, 07/02/2014 - 03:21
  • Red, 2250 points or more
Hello
1-Can you share if you have Cisco MXE cluster , how many resource node?.
2-Did you need to enable a live streaming on Cisco SNS using capture of Cisco MXE ?.
Can you find the below steps:-
I. MXE Setup (this is for WMV but you can also stream differently depending on encoder you use)
1. Setup IP CAPTURE Source.
2. Setup & Configure a ENCODER profile for Live Webcast.
3. Setup & Configure a WEBCAST profile for Live Webcast.
4. [optional] Setup & Configure a NOTIFICATION profile for Live Webcast.
5. Setup & Configure a JOB profile for Live Webcast.
6. Submit LIVE job for IP Streaming.
7. View & Monitor JOB status to verify the Live Job submission was started successfully.
II. SnS Setup – configure a non-DME Live Event and point to IP address and port you have configured on MXE in Webcast profile,  usehttp://www.cisco.com/en/US/docs/video/digital_media_systems/5_x/5_3/showandshare/user/guide/live-events.html#wp1496227
For a Windows Media, URL will be something like http://MXE_IP:9xxx), you need to choose WMV in drop-down.
Please rate all useful information
Related Content
