Warning message
WLC2106 AP Connected to PoE port not detected
Jul 1st, 2014
I have a WLC 2106. It is currently working as expected over AP's that are connected via a remote PoE switch. I wish to attach an AP to one of the local PoE ports.
On a different site we have an identical WLAN controller that was setup before my time, but it is working with an AP attached to a PoE port on the controller.
I can't get this to work on the new controller.
I have read this : https://supportforums.cisco.com/document/53421/connecting-aps-directly-2106
and this : https://supportforums.cisco.com/document/44841/cisco-2100-series-wireles...
and I understand that the configuration I want isn't considered best practice but it is still one I would like to use, I know that it should work as I have a currently functioning example.
From the first document I have linked I have a configuration that matched 'option 2'. I have everything assigned to port 1, AP-MANAGEMENT is untagged and has a DHCP server configured to the DHCP server for the network, and the DHCP server is on the same network as the AP-MANAGEMENT interface.
CDP ALL shows the three AP's that are on the network but not the one that is directly connected.
(Cisco Controller) >show interface summary
Interface Name                   Port Vlan Id  IP Address      Type    Ap Mgr Guest
ap-manager                        1    untagged 10.20.0.13      Static  Yes    No
guestwifi                              1    9        192.168.0.3     Dynamic No     No
management                       1    100      10.20.0.12      Static  No     No
virtual                                     N/A  N/A      1.1.4.1         Static  No     No
The only difference I can see between the two controllers is the software version, with the new one being 7.0.2 and the older one being 7.0.1
Any thoughts?
Finn Rud Laursen Tue, 07/01/2014 - 12:12
Hi.
First you need to make sure the port is enabled with power.
WLC> Config port power all enable
Then make sure the AP have an IP address, otherwise it will not make a join request.
On the AP config this:
capwap ap ip address [IP address] [mask]
capwap ap ip default-gateway [address for the gateway]
capwap ap controller ip address [management interface address on the WLC]
The AP will the join the WLC.
Patrick Whiteside Wed, 07/02/2014 - 08:14
Both ports already show power enabled, and my user at the remote site can see the AP power up.
We have swapped a known working AP onto the PoE port and get the same issue. I have followed DHCP configuration guides for this, and would prefer to use DHCP if possible.
Even if the IP config was wrong, I would still expect to see the AP showing up as a CDP neighbour, which is why I thought there would be some 'lower level' configuration issue at play.
Finn Rud Laursen Wed, 07/02/2014 - 15:28
Have you DHCP proxy en/disabled?
Internal WLC DHCP-server cannot be used when DHCP proxy is disabled.
Related Content
Trending Topics: Other Wireless Mobility
client could not be authenticated
Network Analysis Module (NAM) Products
Cisco 6500 nam
reason 440 driver failure
Cisco password cracker
Cisco Wireless mode
