Warning message
Wireless clients re-association disconnects
Jul 2nd, 2014
Hi, we use a 5508 (7.3.112.0) and 3502i APs.
We are having an issue where multiple clients connecting to a single AP(Like in a training room) are being disconnected or generally having a poor user experience.
I have attached a debug of a failed session, I ran a ping simultaneously to the client also attached
Roaming aggressiveness is set to 3.medium
Any ideas?
Brendan
Leo Laohoo Wed, 07/02/2014 - 22:50
  • Hall of Fame,
    The Hall of Fame designation is a lifetime achievement award based on significant overall achievements in the community.
  • Cisco Designated VIP,
    2017 LAN, Wireless
I'd upgrade to 7.6.120.X.
Brendan Marmont Thu, 07/03/2014 - 18:55
Thanks Leo, I had a quick read through the revision notes, there is nothing there that points to the type of behavior we are experiencing, have you had this type of issue in the field and this is what resolved the problem?
chrebert Thu, 07/03/2014 - 19:33
  • Silver, 250 points or more
Hello Brendan,
You have posted in the Small Business Forums, and we don't usually support the Aironet APs.
You will probably have better luck getting an answer if you move your post to the Wireless Mobility section.
Thank you for choosing Cisco,
Christopher Ebert - Advanced Network Support Engineer
Cisco Small Business Support Center
mohanak Fri, 07/04/2014 - 01:33
  • Gold, 750 points or more
Try this: http://www.cisco.com/en/US/products/ps6366/products_qanda_item09186a00808b4c61.s html
The ability to configure the WPA-Handshake timeout through the WLCs was integrated in software release 4.2 and later. You do not need this option in earlier WLC software versions.
These commands can be used to change the WPA Handshake timeout:
    config advanced eap eapol-key-timeout <value>
    config advanced eap eapol-key-retries <value>
The default values continue to reflect the WLCs current behavior.
   - the default value for eapol-key-timeout is 1 second.
   - the default value for eapol-key-retries is 2 retries
Note: On IOS APs, this setting is configurable with the dot11 wpa handshake command.
You can also configure the other EAP parameters with the options under the config advanced eap command.
(Cisco Controller) >config advanced eap ?
eapol-key-timeout
   Configures EAPOL-Key Timeout in seconds.
eapol-key-retries
   Configures EAPOL-Key Max Retries.
identity-request-timeout
   Configures EAP-Identity-Request Timeout in seconds.
identity-request-retries
   Configures EAP-Identity-Request Max Retries.
key-index
   Configure the key index used for
   dynamic WEP(802.1x) unicast key (PTK).
max-login-ignore-identity-response
   Configure to ignore the same username count
   reaching max in the EAP identity response
request-timeout
   Configures EAP-Request Timeout in seconds.
request-retries
But again, these timings are during an authentication for the uni-cast key, not the group key (multicast/broadcast key).
Trending Topics: Other Wireless Mobility
client could not be authenticated
Network Analysis Module (NAM) Products
Cisco 6500 nam
reason 440 driver failure
Cisco password cracker
Cisco Wireless mode
