07-03-2014 11:55 AM
I'm moving a client from a ISA500 which "appeared" to be easier to setup Port Forwarding from multiple outside IP addresses to 2 different internal mail servers.
I'm confused about how to setup this same configuration on a RV325. Port Range forwarding has fewer options than I'm used to.
Thanks.
07-08-2014 09:34 AM
Hello!
Have you checked out this article entitled, Port Forwarding and Port Triggering on RV320 and RV325 VPN Router Series?
Link to article here:
http://sbkb.cisco.com/CiscoSB/ukp.aspx?login=1&pid=2&app=search&vw=1&articleid=4159
I hope that helps with what you are trying to do.
Please contact me if you have any questions.
Rocket
07-08-2014 10:37 AM
I have seen that article, but it doesn't address multiple public IP (outside) addresses going to different private (internal) addresses.
IE: mail.abc.com (port 25) coming in on 1.1.1.1 going to 192.168.1.1 and mail.def.com (port 25) coming in on 1.1.1.2 going to 192.168.1.2.
07-08-2014 06:19 PM
If you want to enable port-forwarding from multiple outside IP addresses to multiple internal IP address destinations, you need to follow the steps I outlined here:
https://supportforums.cisco.com/discussion/12216481/rv320-port-forwarding-specific-wan-ip
