SNMPV3 enabled but only get snmpv2 traps
Jul 7th, 2014
Hello
I have a 3750X switch setup so that gig 1/0/1 is sending  an inform back to a server whenever the server changes the vlans on the port.
It works fine with snmpv2 but we have to switch to V3 for security reason.
I have everything setup for V3 but the switch still only sends out V2 traps
The snmpv3 user is setup correctly and the username matches the server host.
The user can make the vlan change using V3 but the switch is only sending out v2 traps.
anybody run into this before ?
gig 1/0/1
snmp trap mac-notification change  added
snmp trap mac-notification change removed
snmp-server enable traps mac-notfication change move threshold
snmp-server host <IP> informs version 3 priv <username> mac-notification
