Warning message
Is it possible to enable "Rtp control protocol" in cisco 7942g series xml config files?
Answered Question
Jul 7th, 2014
I can see on 7942g settings menu that "Rtp control protocol" is disabled, but it is not editable and as I'm not using cucm I need to enable it some other way. is it possible to enable it from xml  configuration files?
Correct Answer by bernhardczapp about 3 years 1 month ago
to enable RTCP you can use
<vendorConfig>
<rtcp>1</rtcp>
</vendorConfig>
within the SEPXXXXXXXXXXXX.cnf.xml file.
Overall Rating: 5 (1 ratings)
Correct Answer
bernhardczapp Thu, 07/10/2014 - 06:41
  • Bronze, 100 points or more
<vendorConfig>
<rtcp>1</rtcp>
</vendorConfig>
