07-08-2014 04:06 PM - edited 03-07-2019 07:59 PM
I have a question regarding the following configuration.
In this scenario, should the route map pick up the traffic from this server? I don't see why not, but in my testing it doesn't seem to be working :)
Thanks for any help.
Solved! Go to Solution.
07-08-2014 04:57 PM
What kind of switch and IOS version are you running.
Just a pointer if you are using a 3750 you should
change the SDM template to:-
sdm prefer routing
then configure your acces list, route maps etc
Alex
07-08-2014 04:57 PM
sdm prefer routing
Alex
07-09-2014 03:31 AM
Hi Alex,
It's a 3750x (stack) with 12.2(55)SE5.
I've already changed the SDM template to routing and rebooted the switch.
I don't think the route map is working at all actually :) See config below, let me know if you can spot anything obvious but the networks on the ACL are definitely correct.
Thanks again.
Extended IP access list UPLINK2
10 permit ip 192.168.1.0 0.0.0.255 any
20 permit ip 192.168.4.0 0.0.1.255 any (305 matches)
route-map ROUTE1 permit 10
match ip address UPLINK2
set ip next-hop 10.1.1.253
interface Vlan10
ip address 192.168.5.254 255.255.254.0
ip policy route-map ROUTE1
end
07-09-2014 03:48 AM
Hello
try
conf t
ip local policy route-map ROUTE1
res
Paul
07-09-2014 04:56 AM
Hi Paul,
Wouldn't that only affect the traffic coming from the switch/router itself?
Cheers
07-10-2014 02:09 AM
Turns out you have to re-create the route-map after changing the SDM template to routing. Even though this is not documented it's what worked.
Thanks for the help everyone.
