Warning message
NAT overlap inpact on cat6500 (sup720)
Jul 8th, 2014
I am planning to put two NAT on cat6500 for two private subnets. just briefly search on the web, and found there is some comments on the NAT will have impact on cat6500 perfermence. I know my cat6500  is using heavily. so would like to get some advice if it will cause any issue?
the subnet I want to nat is two private subnets, I said 10.1.1.0/24 and 10.2.2.0/24 and I would put them on two public ip addresses.
do I will get perfermence impact dramitically? if so, is any work around I can use?
Any comments will appriciated
Thanks in advance
julxu
