Warning message
UCS Manager - internal system backup failed [FSM:FAILED]
Answered Question
Jul 9th, 2014
I have UCS Manager Version 2.2(1c)
I set up configuration backup via SCP, and Im getting error.
Destination is accessible from other computer in same VLAN via WinSCP.
I need help what exactly is causing that error from UCS Manager, and how to solve this issue.
I tried to delete and again add backup  job operation.
Severity: Critical
[FWS:FAILED]: internal system backup
Type: fsm
Cause: fsm-failed
Code: F999723
I am waiting for quick replay.
Cheers.
Correct Answer by Lukasz.nowicki1 about 3 years 1 month ago
Looking at the logs you posted there is a mismatch in algorithms betwen scp server and ucs system. Server is accepting aes-ctr and ucs is using aes-cbc ?
Maybe try adding
"Ciphers aes128-ctr,aes192-ctr,aes256-ctr,aes128-cbc"  to /etc/ssh/sshd_conf
Overall Rating: 5 (1 ratings)
Walter Dey Wed, 07/09/2014 - 08:38
  • Red, 2250 points or more
  • Cisco Designated VIP,
    2017 Unified Computing, Storage Networking
Does scp work from the host you connect to UCSM ?
What OS for scp server
any firewall ?
I assume you never get to the point, where you have to enter a pw ?
pwojtachnio Wed, 07/09/2014 - 11:42
Hello wdey,
I am able to connect from some other server (Windows Server) to that SCP backup server (Linux)
Both hosts I mean UCS Manager, Backup Linux server, and Windows Server are in the same VLAN. (management). So there is no firewall.
What do you mean
"I assume you never get to the point, where you have to enter a pw ?"
Cheers and I am waiting for quick replay.
Walter Dey Wed, 07/09/2014 - 11:58
Can you please post a screenshot of the backup configuration, as well as the full error message !
Would you mind trying this with CLI
SSH to the Fabric Interconnect
Change to the system scope by typing “scope system”
create backup scp://[email protected]/home/ucsbackup/fabricInterconnectName_all_configuration.bak all-configuration enabled
Go back to the scope system (type exit)
Note: ucsbackup is the username you login to your SCP server with. After each create backup command is issued you will be required to put in the password, this is a onetime process.
pwojtachnio Wed, 07/09/2014 - 12:25
Hey wdey,
Yes, I sorry, i forgot provide output from CLI.
I tried to push
FABRIC(local-mgmt)# copy workspace:/techsupport/some_date_here.tar scp:[email protected]_IP_address
no matching cipher found: client aes128-cbc,3des-cbc,aes192-cbc,aes256-cbc,[email protected] server aes128-ctr,aes192-ctr,aes256-ctr
lost connection
With your hints, i did and ...
FABRIC  /system # create backup scp:[email protected]_is_IP_ADDRESS/home/ucsbacku                                        p/fabricInterconnectName_all_configuration.bak all-configuration enabled
Password:    [here i typed password of course]
FABRIC /system/backup* #
FABRIC /system/backup* # exit
from server
[[email protected]_backup_server ~]$ ls -la
total 28
drwx------  3 ucsbackup ucsbackup 4096 Jul  8 16:41 .
drwxr-xr-x. 9 root      root      4096 Jul  3 14:30 ..
-rw-------  1 ucsbackup ucsbackup  176 Jul  9 19:56 .bash_history
-rw-r--r--  1 ucsbackup ucsbackup   18 Jul  9  2013 .bash_logout
-rw-r--r--  1 ucsbackup ucsbackup  176 Jul  9  2013 .bash_profile
-rw-r--r--  1 ucsbackup ucsbackup  124 Jul  9  2013 .bashrc
As you can see, empty
Walter Dey Wed, 07/09/2014 - 12:35
If I understand you correctly, with CLI, you can connect to the scp server (therefore network connectivity is ok), enter a pw, and the backup finishes without an error message, the proper file is created, but it is empty ? correct ?
pwojtachnio Wed, 07/09/2014 - 12:37
Hey,
Wdey, that is correct, after typed password i suppose t see some progress % % %
But I didnt see....
Walter Dey Wed, 07/09/2014 - 12:42
Not sure, that one sees a progress bar !
Did you just out of curiosity try another method, like ftp, tftp,.....or even to the local system.
I know scp has been done in the past; not myself however !
pwojtachnio Wed, 07/09/2014 - 12:50
Hi Wdey,
I didnt check other methods.
Could you provide some example of local system...
Maybe there is a problem with ssh certificates ? on ucs side ? maybe same linux side, i dont know....
Correct Answer
Lukasz.nowicki1 Fri, 07/11/2014 - 03:27
Maybe try adding
Walter Dey Thu, 07/10/2014 - 02:07
I would open a TAC case ! strange that CLI doesn't bring you the same error !
