07-10-2014 12:26 AM - edited 03-07-2019 08:00 PM
I have a pair of older 2821 routers doing site to site VPN termination. They use HSRP on the external interface, with "tunnel source" mapping to the respective HSRP addresses.
Running 12.4(25)g, a tunnel with the source of an inactive HSRP address would show as "line up, line protocol down". If the router went HSRP active, then the tunnel would change to "line up, line protocol up"
After upgrading to 15.0(1)M10, the tunnels always show up/up regardless of HSRP state. I'm using OSPF to do the routing so OSPF will only come up if the HSRP state and tunnel source match, but this is really weird behavior to me. In a different data center I have a pair of 2921s with similar configuration, and they are correctly marking tunnels up/down if not HSRP active
Any ideas on this one?
07-10-2014 12:38 AM
Here's a sample of the configuration, since I'm sure I'll be asked:
Router 1 (HSRP active for 198.18.0.100)
interface GigabitEthernet0/0 ip address 198.18.0.111 255.255.255.0 duplex auto speed auto standby delay minimum 90 standby 1 ip 198.18.0.100 standby 1 priority 255 standby 1 preempt standby 2 ip 198.18.0.200 standby 2 priority 254 ! interface Tunnel100 description Main Tunnel via 100Mb bandwidth 100000 ip address 192.168.255.1 255.255.255.252 ip ospf network point-to-point ip ospf mtu-ignore load-interval 30 keepalive 10 3 tunnel source 198.18.0.100 tunnel mode ipsec ipv4 tunnel destination 1.2.3.4 tunnel protection ipsec profile COMPAT ! interface Tunnel200 description Backup Tunnel via DSL bandwidth 6000 ip address 192.168.255.5 255.255.255.252 ip ospf network point-to-point ip ospf mtu-ignore load-interval 30 keepalive 10 3 tunnel source 198.18.0.200 tunnel mode ipsec ipv4 tunnel destination 5.6.7.8 tunnel protection ipsec profile COMPAT !
Router 2 (HSRP active for 198.18.0.200)
interface GigabitEthernet0/0 ip address 198.18.0.222 255.255.255.0 duplex auto speed auto standby delay minimum 90 standby 1 ip 198.18.0.100 standby 1 priority 254 standby 2 ip 198.18.0.200 standby 2 priority 255 standby 2 preempt ! interface Tunnel100 description Main Tunnel via 100Mb bandwidth 100000 ip address 192.168.255.1 255.255.255.252 ip ospf network point-to-point ip ospf mtu-ignore load-interval 30 keepalive 10 3 tunnel source 198.18.0.100 tunnel mode ipsec ipv4 tunnel destination 1.2.3.4 tunnel protection ipsec profile COMPAT ! interface Tunnel200 description Backup Tunnel via DSL bandwidth 6000 ip address 192.168.255.5 255.255.255.252 ip ospf network point-to-point ip ospf mtu-ignore load-interval 30 keepalive 10 3 tunnel source 198.18.0.200 tunnel mode ipsec ipv4 tunnel destination 5.6.7.8 tunnel protection ipsec profile COMPAT !
