UCCX 8.5 Supervisor Desktop Plug In
Jul 10th, 2014
Just downloaded Supervisor Desktop from UCCX 8.5 but when I open the program and attempt to select team, there are no choices; only select team, no drop down like my coworkers have.
Tanner Ezell Thu, 07/10/2014 - 16:36
  • Silver, 250 points or more
You'll need to assign the supervisor to a couple teams before you'll see anything in Supervisor desktop.
You can do this through SubSystems --> RmCm --> Teams. Make sure your user shows up under the assigned section.
You will need to close (completely) Cisco Agent Desktop and relaunch before you will see the changes.
Tanner Ezell
