Warning message
Monitor multiple conferences from a phone
Jul 14th, 2014
Hi all! Figured I would make my first post an interesting one! Here is what I'm trying to accomplish - two meet me or ad hoc conferences are in process, I would like to be able to take a separate phone and listen to both conferences at the same time.
I looked into RSM but from what I can find I can only listen to a single call at one time.
Any help would be great - I'm running out of ideas
tonyperla Thu, 07/17/2014 - 06:04
  • Silver, 250 points or more
Hi Andrew,
What version of UCM are you running?  Browsing through some release notes, there doesn't seem to be any native options to UCM that would grant you the ability to listen to multiple conference calls from a single line.  I know that some third party applications that use a form of software installed on a PC will show the conferences ongoing.  You can select them to monitor but that is only when using their conferencing solution and its is a single conf call at a time.
Hope this helps
Tony
Please rate helpful posts
