authentication mac-move permit
ataro
I want to question in relation to the command "authentication mac-move permit".
This is either a recognized settings to allow the movement of the same switch, not a setting that allows you to move to other switches?
(used Wired 802.1x.)
When not authenticated to move the terminal to other switches, it went well You can use this command.
Thanks.
Rajeev Sharma
Hey,
Regarding your question:
This is either a recognized settings to allow the movement of the same switch, not a setting that allows you to move to other switches? - You are correct, mac move is allowed only on a single switch.
HTH.
RS.
Rajeev Sharma
Hey,
HTH.
RS.
Hi,rajeevsh
thank you.
It's does not lead to another reason is likely.
(hmmm)
I will investigate again.
